If
the machine is plugged into a working outlet, make sure the safety key
is in the keyhole on the console. If the safety key is not plugged into
the machine or if it is pulled out during operation, the treadmill will
not operate.
Finally, make sure the circuit breaker located on
the frame near the power cord is set to "Reset." The circuit breaker is
set to "Reset" if the top of the button is pushed in. When the breaker
is tripped, push it back to the "Reset" position and wait five minutes
before powering on the treadmill.
If the treadmill shuts
off during operation, check the power cord and circuit breaker as
described above. You can also try removing and reinserting the safety
key.
This just means that the elevation is out of range. It probably lost its signal when you moved it. The way to fix this is to recalibrate it. You can do an auto recalibration.
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
STEP 1 ENTER ENGINEERING MODE With the safety key in place, hold "ELEVATION UP" and "SPEED DOWN" buttons for 5 seconds. Software version will appear in display window for a few seconds before model displays. Press "STOP" , "ENG1" will appear in display window. STEP 2 AUTO-CALIBRATE Press "ELEVATION UP" until "ENG4" is displayed. Press "SELECT" , display will read "AUTO". Press "START". Unit will calibrate, when finished "END" appears in display window, then "ENG1". STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
That was the lamest response (no offense) I have already done all the basics including holding down keys and cleaning plugs. Do you have anything else for me?
vision fitness treadmill e6 code but wont auto calibrate
