SOURCE: how to change language from
Try this:
Press the "Menu" button and locate the "Settings" (should look like a spanner), press "Ok" or "Select", once it's opened, locate the "phone settings" (it looks like a phone receiver or like a mobile handset) using the up and down key, open it and then the again select the first from the list (that should be theLanguage settings), once it's opened, you'll see the english language written in english as "English", select it [or you can just select "Automatic" if it's default language was "English"]. Now, the language of your mobile will change back to English.
If you need further help, let me know with more details.
Good luck.
Thanks for using FixYa.
First go to Menu. Then click on settings. It has d screwdriver icon. Click on it. Then scroll down to 'Phone' which is the 11th button. Click it. There u have the 1st button. language or in hindi it says Bhaasha. Click it. Then u will get phone bhaasha. Clicking it will open the languages. Click on English or any other language required.
Thx....
On your phone menu select "settings" then "phone settings" then select " language". Once you see all the available language that can be used, select the Hindi language or any language you want. Thats it, just remember this steps when you are going to change the language setting again in the future.
SOURCE: how to change nokia 2690
press
Menu > Setting > Phone > Language setting > phone language
and select your language in the list while pressing the phone language
