u might have to change your settings under your profiles... go to the profile and then edit under whichever profile is the one u are currently using and then go down to phone and scroll all the way down where it says do not disturb and be sure it says no. if it says yes then it will go straight to voicemail
What is your alcatel model? You can easily unlock your alcatel phone by using unlock code. If you need unlock code you can visit this site Mobileunlocksolutions.com here you can get the code and unlock your mobile easily. To get the code you have to mentioned your alcatel model,which country is locked now,network provider and imei number. Then they send unlock code through email. Mobileunlocksolutions.com
You can reset Alcatel phone using Master Reset Code. It will reset your phone, removing any security locks(except network locks) . To get the master reset code for free visit Unlock-Free.com . They provide master reset code for some old model Alcatel phones.
Attendant To apply Do Not Disturb on an extension: • Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?. • Dial the desired extension number. • Press the DND ON softkey. • If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension. • Press the EXIT softkey. To remove Do Not Disturb on an extension: • Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?. • Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB. • Press the DND OFF softkey. • If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension. • Press the EXIT softkey.
