Can you tell me the correct method for changing blades on a Dewalt DW733 Planer?
Click here
this might help you
Click here to get the user's guide. Check page # 9 for adjusting or replacing the blades.
This is a direct link to the PDF file. English is 3/4 way down
https://service.toolcommerce.com/PDMSDocuments/EU/Docs//docpdf/dw733_eur.pdf
Remove power cord.
Lock blade in position using the lever on the right,
Unbolt 6 central bolts using tool provided,
Unbolt End 2 bolts, and remove blade.
To reset, Mount new blade, Bolt in 2 end bolts.
Use magnetic setting tools to set depth, and tighten central bolts.
Remove magnetic setting tools, Check free rotation, Replace opposite blade.
Sorry, Link not working - Here
https://service.toolcommerce.com/PDMSDoc...
They are so lock tight tight first time that the bad fit wrench provided rounds off the only two flats reachable. We ended up filing out an undersized spanner to get the job done.
Much of the links are have changed but from here you can fill up for the tool you want.
http://servicenet.dewalt.com/
Just read the manual once before taking any action .......... you just need to remove appropriate screws ......the connections have to be taken care before changing the blade
there are various site where you can get lot of information about how to change blade here is one site try this http://www.inthewoodshop.org/faq/faq.sht...
I do not have a manual to read or I probably could read it .
I do not see a box to accept your solution
I still do not see a way to accept your solution so I can authorize for you to be paid
