RIM BlackBerry Storm 9530 Smartphone Logo
Posted on Nov 30, 2010
Uncaught exception 11>=11 bb
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1221
Points
16
My phone went dead last night went i was in bed and when ive woke up this mornin ive put it on charge and the screen was white and said app error 523 reset so i reset it and it says uncaught exception:11 >11 and then went i press ok it just goes straight back to app error 523 .... and i need my phone :( how can i fix it without sending it off and paying for it?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
868
Points
Same problem!! :(
is ur problem solved?
When i turn on mybb curve it shows uncaught exception: index 11>=11 how should i fix it
tHE OPNLY WAY TO FIX THIS IS TO DO A BACK UP AND THEN RELAOD THE SOFTWARE VIA THE BLACKBERRY DESKTOP SOFTWARE ..WHICH YOU CAN DOWNLOAD FROM THE BLACKBERRY WEBSITE , WHICH IS LOACTED UNDER SOFTWARE
Uncaught exception: index 13>=13 app
How To Reload Your Operating System
Here is a KB that discusses that error:
  • KB16471 BlackBerry Desktop Software prompts that an Internet connection is required to configure synchronization
Hopefully it contains something useful!
As an alternate method, from a PC, you can install any OS package to a BB via this procedure:
Note that while written for "reload" and the Storm, it can be used to upgrade, downgrade, or reload any BB device model -- it all depends on the OS package you download and install to your PC. You can even use a different carriers OS package by simply inserting, between steps 1 and 2, the deletion, on your PC, of a file named VENDOR.XML. Be sure that you remove, from your PC, any other BB device OS packages as having more than one installed to the PC can cause conflicts with this procedure.
If you are on MAC, you are limited to only your carriers sanctioned OS packages...but can still use any levels that they currently sanction. See this procedure:
  • KB19915How to perform a clean reload of BlackBerry smartphone application software using BlackBerry Desktop Software
BlackBerry Storm 9550 Problem On IM3 network in Indonesia, over the last few months when rebooting my Storm 9550 it starts up with uncaught exceptions. My wife and I thougt at first I had a vrus with the...
Try this David. Gte on your computer and by using the blackberry desktop software back up your phone. Now after doing that get your phone and go to the options menu (The little wrench icon) and look where it says security and click on it. Now if you press the menu button it should give you the option of wiping your handset by doing this it will erase everything off your phone and it will be just like it was when you bought it. Try all the functions and if they work you have a virus if they do not work your phone is bad.
Feb 09, 2011 • Cell Phones
2answers
5helpful
3answers
I turn on the phone to immediately find a pop up that says uncaught exception index 4>=4 then by its self it will go to w white screen that says app error 523 with a reset link beneath it. ive tried...
i turn on the phone to immediately find a pop up that says uncaught exception index 6>=6 then by its self it will go to white screen that says app error 523 with a reset link beneath it
19helpful
4answers
How to fix blackberry 8520 app error 523
just wipe it or reload with the new updated OS
1helpful
I'm getting Uncaught Exception - Process Terminated in my BB app installed on BB Bold device. It does not come all the time only at few occasions that too when after 2-3 days of the app's installation....
well one u messed up a piece of wiring in ur phone so take out the battery and then unscrew the back if the red wire has scratches or has been cut in a way there is ur problem if thats it u will need to take back the phone
1helpful
I keep getting this error on my BB Storm 9500. Uncaught Exception: java.lang.NullPointerException How do i solve it?
I had this same problem for months and couldnt figure out why. Then I just completed the latest update and it is now gone!
1helpful
I cant get into my text messages on my BB Storm?
My name is Maureen Uwechia.
I had the same problem but I was able to find a way round it. I switched off the phone (blackberry storm), removed my sim, put the sim back after some minutes and put on the phone. Simple!! It worked.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
