Perform a Factory Reset:
1) Plug unit into AC power, so that all the lights come on as mentioned.
2) Press and hold "MENU", "ENTER" and "INPUT" (all together) for at least 5 seconds. Error lights will clear.
3) Turn OFF by POWER button, wait a few seconds.
4) Turn power ON by pressing the POWER button.
The projector will turn ON, but will take a while (1-2 minutes) to load firmware.
5) Recommend to go into Menu and at the very bottom use the "restore all defaults"
I have just serviced a Casio projector similar to this unit. I cleaned the ribbon cable connectors with a burnishing brush. I also found two screws that were jammed between a circuit board and the optical block. After cleaning the connectors and removing those two screws the projector started working fine.
This is fairly uncommon for a repair, but it may be worth a try.
FIRST LOCALIZE THE UP/ DOWN/ LEFT/ RIGHT AND MIDLE BUTON- ON FUNCTION CONTROL
OK...
KEEP PRESSD FOR 10 SEC
INPUT / MIDLE BUTTON FROM FUNCTIONS/ AND RIGHT ARROW
RELEASE THOSE BUTTONS
NOW YOU SHULD GET THE ERROR RESETED.
NOW YOU HAVE TO INITIALIZE THE UNIT:
POWER OFF UNIT( FROM POWER BUTTON)
POWER ON
PRESS AGAIN: INPUT/ MIDLE BUTON/ RIGHT AROW TILL SHOWS A SERVICE MENU ON SCREEN
CHOSE INITIALIZING AND RESEAT UNIT.
GOOD LUCK...GO CANUCKS
We had a projector in for repair with a similar if not the same problem. Casio said it was locked up and had to be reset internally. We had the temp and lamp lights blinking red and the power light was solid red no blinking. The unit would not power on. Would the above procedure work in this case or is there an actual internal reset that has to be done?
http://support.casio.com/pdf/007/xj_460_... Section E-30
i too am having this problem, i even swapped out the bulb but i still have a solid red POWER indicator and flashing amber INPUT and TEMP lights
Kindly get intouch with Cinesonic Audio Visual Pvt. Ltd. in New Delhi at 10/2, DLFIndustrial Area, Shivaji Marg, Moti Nagar,
New Delhi-110015
Contact: ' Board: +91-11-47424444 (30 Lines)'
e-mail: Robert@cavpl.com
For any problem related to Casio Projectors
I Have Casio XJ-M155 That i want to reset lamp timer
