I do not think there was a driver version 1.5 for the 8008 I
believe only one version of driver was released for the 8008 for XP this was version 1.00
I think your search for later driver will be fruitless.TallyGenicom went Chapter 11 and are no more, I think
thwy were taken over by
dascom (
www.dascom.com) who now sell Tally Dot Matrix printers.
I think your best option would be to check how the
pritner is connected.
If connected via
USB ensure the printer is correctly plugged in, make sure you have the
USB cable connected to the
USB port on the printer NOT the network port (it happens!!)
Plug the printer into a different
USB port on the PC in case there is problem with the particular port.
Try a test page from the printer driver once you have installed it, see what errors you get.
If the
printer is networked, ensure you can PING the IP Address, in the printer driver ADD A STANDARD TCP/IP port to print to the printers IP Address.
Post any errors or
specific problems you see, how the pritner is connected we may be able to help some more.
Try 172.24.16.24 if you are in the range. Is this first installation ?
