Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer Logo
Posted on Dec 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is MP tray? - Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on Dec 01, 2010
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
833138
Points
6040
The MP Tray is just above the main paper tray and can be accessed by opening the MP Tray door. To open, pull on either the left or right side of the front door by the circular cutout.
How do I clear a scanner jam for a MFC 8480
Hi Judy,
Please follow the steps posted below:
1. Remove the paper from the MP tray
2. Remove any jammed paper from in and
around the MP tray
3. Close the MP tray. Then open the front
cover and close it to reset the machine.
4. Open the MP tray again
5. Fan the paper stack, and then put it back
in the MP tray
6. When loading paper in the MP tray,
make sure that the paper stays under
the maximum paper height guides on
both sides of the tray
Let me know if this resolves the issue,
Thanks,
Hunter Quinn
IBM Help Desk
My Brother HL 4040cn showes a Jam MP Tray. There are no papers jambed but it will not reset.
Hi James,
Remove the paper from the MP tray.
Remove any jammed paper from in and around the MP tray.
Fan the paper stack, and then put it back in the MP tray.
When loading paper in the MP tray, make sure that the paper stays under the maximum paper height guides (1) on both sides of the tray.
Press Black (Mono) Start or Color (Colour) Start to resume printing.
Still having Problem Then follow Us For
Brother Printer Support
Manual feed isnt working. once tray 1 is open i thought it would automatically know i want to use manual feed.
Not necesarily so, it depends on how you have the printer configured. To test the MP tray, use the arrow keys to get to troubleshooting menu, press check, use arrow keys to get to paper path test, press check, set tray option to tray 1, then print test page. Printer should feed from MP tray. If it does, then the problem is that you do not have the printer set to print from MP tray first or you have the tray options set to exclusive which means that if your print job asks for tray 2 then printer will not print from MP tray unless you specify MP tray in the print options.
Trying to print labels, but error reads load mp tray. Where is this MP Tray?
MP is the tray in the front it looks like a door on the front. When you open it it turns into a tray for you to put the label paper on.
What is a mp tray
MP tray: Manual Paper tray
Where: go into printer properties-> Paper Source
change from Auto to MP tray, you will see where it is.
Gudluk
1helpful
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
3helpful
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Can this printer automatically choose the paper tray i.e. if the MP tray is open will it choose that instead of the cassette?
MP tray needs to be set on FIRST*
When paper is in MP tray, thats where the printer will automatically take it from. When there is no paper in the MP tray, or it is closed, the printer will take from the cassette.
1helpful
IBM infoprint 1422 won't feed through paper tray, only works with mp loader
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
2answers
Fs-1030d even when set tray1 as source will print from mp feeder if paper in it
If paper in mp tray it can print mp tray only,
There is no option to chane the settings.
Norman Weimar
Norman Weimar
k24674
