I do't know how or where to go to donwload the original software for a fuji finepix s700 camera, what i did see was very confusing. i need to transter pictures to my pc from my cam. i have done this many times, but now the cam won't download. i was trying to fix the problem and uninstalled the software.
PLEASE HELP!
Here you go...
Support and Contact Center
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
SOURCE: Need Fuji FinePix 2650 Software
Try the fuji 800 number they may be able to sell you a new driver cd. otherwise you can buy a card reader at any camera store that will eliminate the need for software completely for about $15.
SOURCE: I need a new lcd screen for my fuji finepix s700,
i also need a screen even ebay dont have any......
SOURCE: lost installation cd for fugi finepix s700 camera
The information you need can be obtained at this websit.
Hope this helps you.
John Ray
[email protected]
http://www.fujifilmusa.com/support/ServiceSupportBrowse.do?prodcat=644675&sscucatid=664269
SOURCE: flash not popping up or
The S700 does NOT have a manual release for the flash to pop up, but it DOES have a spring already. DO NOT try to force it! Set the flash to "FORCE", leave your lens cap on and waste a shot to allow the flash hood to pop up. Reset your flash to the desired setting and now the flash is already open and ready for use without the delay and the startling effect it has when your concentrating on framing your shot. As for the other problem of no flash in any setting: Check your menus to see if you have the flash totally disabled, check your batteries, does the "charge indicating light" come on at all between shots? In RARE cases, the actual bulb that flashes may be burned out, or a component in the flash circuit itself,such as the capacitor, may have gone bad. Did the flash ever work? If under warranty, return for repair or replacement. There are NO user serviceable parts in these tiny cameras
want to download original software for finepix S700. Lost disc ,want to put on new computer.
dony have software to download on my new computer...I can not transfer any photos?
i ned the installation disc
