Touchpad zone is on upper left of the touchpad: Turning the TouchPad on and off The TouchPad is turned on at the factory. When the TouchPad zone is active, the light is off. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
To turn the TouchPad on and off, quickly double-tap the TouchPad off indicator.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
It works... Thank you!
Thank you is a easy proccess but if you dont know, you may be try for a couple minutes whitout success
Thanks for having the answer to a frustrating problem. So very simple once you know what to do. Thanks
Hello Sir,
I have this HP pro book 4520s. the problem i am facing is that the mouse pad is very sensitive and i am unable to write any thing my hand touches the mouse pad and it moves to some other place . the option you are talking about above i am unble able to use it even tapping it , it is not working and i am unable to find any option there in windows where i can disable the touch pad so that i am can use the keyboard properly.
Regards
Perfect solution!!!!!!!!!!
Thank you for posting this. I also learned a couple of things.....Be sure to double tap the "light" on the touch pad to enable it. When booting the computer, you will see a fade out icon in the middle of your monitor with an X on it indicating that the touchpad had been disabled.
And yes, you can have both the touch pad and a mouse working at the same time
Wonderful it works thank you
its works now, easy but wasnt clear, thanks a lot
This worked for me.
Thanks!
Thanks Joe but I did that it doesn't help. the light is not on, the mouse pad still on
hi Joe, thank you very much for the tips. it works for me!
I have laptop (hp probook 4520s), touchpad is not working. How do I re-activate it?
Bingo it works. Can't believe it. Bn thinking of taking it to an engineer. Cheers mate
My touch pad dosen't lock
It worked perfectly
SOURCE: Hi, i jst bought a new hp laptop probook 4520s
Hello silinsalim, follow these instructions for the "Touchpad," First, click on the "Start Button." "In the (right, area), select to open the Control Panel. Next in the [Hardware and Sound] category. Choose the "Mouse" 'applet.' Next in the "Mouse Properties" (window) click on the "Device Setting" button. Once the window open, click on the "Setting" button. It located, just below the "highlighted" (Name of the device TouchPad. Try out some of the "items listed." Tapping, Virtual Scrolling... "You must click on the "Apply, OK buttons when finished If this information helped? Return and give a "Helpful Rating," please!
Attention! "Manually" Install Driver; select "Update Driver"
Follow all the instructions."
Note: "Restarting the computer will configure system changes in the computer applications to prevent errors and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware."
Thanks, paul7of9
SOURCE: how to unlock touchpad of hp probook 4520s
when you open a touchpad setting application you have to enable(check) radio buttons.
SOURCE: How to unlock the mouse
look at the trackpad on your laptop. There is little dot in the upper left. Double-tap that dot.
help
Can't boot from USB
