Usually your camera comes with a USB cable which enables you connect it to the PC. Connect the camera to the PC a couple of files will appear under the camera icon under computer check these files and the pictures which are in your internal memory can be found there.
Highlight the pictures right click on them copy and paste them in the location you want them to be on your computer.
Hope this solution has been helpful?
Simply remove the memory card from your camera before connecting the camera to your computer. The computer will then see the camera's internal memory instead of the card memory, and you can copy the pictures over.
If you have been accessing your pictures by removing the card from the camera and placing it in a card reader attached to your computer, then this won't work for pictures in the internal memory. You will need to use the other method, connecting the camera to the computer with the USB lead.
