I accidentally dropped my SB 600. It was in the case. Now it won't turn on at all. Changed the batteries too. Nothing. There are no scratches or marks and nothing is damaged on the outside.
Did you clean the contacts in the SB-600 when you discovered the corroded batteries? I use a pencil eraser followed by alcohol on a Q-tip. Make sure that all of the contacts are shinny and there is no remaining sulfate residue. If that does not solve the problem, there are other issues.
Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
Does the flash turn on when you push the battery door down? By push it, I mean HARD... If so, you might be able to cure this by getting some jewelry screwdrivers and flexing IN the metal contacts in the battery compartment door to increase the battery contact.. just be careful not to break the metal (but if you do, a replacement battery cover is about $16)
Batteries may have leaked. Open battery chamber and clean ---especially the contacts situated at the bottom -- with pencil erazor. Blow out any loose bits and with new batteries try to switch the unit on.
