The upper and lower shell snap together. I removed screws from the bottom and could not separate the shell. I them unscrewed the metal shroud from the inside and removed it. It is a tight fit. You will see the snaps inside. I pushed on a couple of the snaps and the shell came apart. I am sure you will be able to address your issue from there. I am trying to find out why the heating element won't work on my machine.
The belt is not easy to access. After the screws are removed from underneath, the bolts inside the baking area need to be removed, then the plastic case can lift off though it may be helpful to remove the metal shroud from inside the baking area to access the snaps connecting the two plastic parts. Then, the switch panel is connected to the circuit board by a flat cable and this prevents the top plastic housing from coming off. I kept it attached and just worked around it but it could be removed. then the metal plate on the bottom has a few screws holding it to the bottom plastic piece. once those are removed, the belt can be accessed. it's a hassle.
This info helped but we never got it apart
