OK... from the schematics it appears that when in mon1/mono mode you use ONLY the MON1 gain controls, including the channel MON1's and the MON1 slider. Make sure you have each of those turned up as needed. In this mode, MON2,s and the MON2 slider are unused. The MONO slider controls the MAIN output.
Also, PLEASE read my tip about PMP mixers on FIXYA tips. There is a hazard if you are using Speakon to 1/4 inch connectors. Channel "A" will have the SLEEVE of the plug hot instead of the tip and if you ground the sleeve accidentally or connect a grounded device as a daisy chain off of cahnnel "A" you are likely to damage the amp...
