Question about Toshiba Regza 46RV525U 46 in. LCD HDTV
I have double picture on right side of screen.almost like you can see the square boxes.it is a 46 renza lcd
  • 11,361 Answers
It does this in ALL video sources? That is the symptom of bad T-CON board. Is this TV still under warranty. There is a slight chance of bad LCD panel also.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 04, 2010
6ya staff
SOURCE:
Hi, sorry for my english. I have Toshiba 46RV525U. The screen have verticals lines and the image doubles, just on the left side.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 08, 2016 | Toshiba Regza 46RV525U 46 in. LCD HDTV
ON THE VERY TOP OF SCREEN, I HAVE LINE WITH "NO SIGNAL" ON LEFT SIDE AND A NUMBER 3 ON THE RIGHT SIDE. ANY SUGGESTIONS
You might just need to press the source button on TV remote so a box pops up on the screen giving you options like tv,hdmi1,hdmi2 or av1,av2. Hopefully its a little helpful.
May 30, 2015 | Sony BRAVIA KDL-46S2010 46" LCD TV
Samsung lcd tv with double image on screen
T'Con board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Samsung LN46B610 46 HDTVReady LCD TV
Left side is dark and right side is good
The LCD sets use backlights and also a pair (some models combine both into one unit) of inverters- one drives left side and the other right side.
You could have a bad inverter (some versions call it T-con) or even a bad display panel(main screen unit).
In most cases this is not a do it yourself repair.
May 17, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Screen dark on right hand side at start up
Suggest return or exchange. This is a newest model, and on factory warranty, if can't return or exchange, you have to complaint it until the panel is replaced. in fact, it is 90% panel defective. right now the LCD panel quality is too bad.
Jun 17, 2010 | Sony KDL46EX500 46 in. HD-Ready TV
Half of my lcd tv gets dark no picture
Find your warranty papers....may be a defective screen.
Apr 21, 2010 | Samsung LA46A550 46 in. HD-Ready LCD TV
Lines or doubling on one side of screen
The last Sony LCD set I had with a problem a bit like this had a bad LCD drive board. This is the board at the top of the set--that connects between the LCD panel and the main board.
Oct 09, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Mar 08, 2008 | Samsung LN-T4671F 46 in. LCD Television
Toshiba Regza 46RV525U 46 in. LCD HDTV Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
