Question about Westinghouse Televison & Video
Need to know how to use remote for my westinghouse HD Flat screen. Model # LTV-32w3 HD. Is there an instruction manual i can download?
  • 11,361 Answers
6ya staff
SOURCE:
Ltv 32w3 coax disabled
Google the model number with "manual" to try to locate the owner manual which if the set has such a feature (not likely) will tell how to unlock it.
My guess is set has a bad tuner etc and someone just wanted to dump it on you.
May 31, 2012 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Westinghouse LTV 32w3 HD LCD TV (LTV32w3HD)and it does not come on. I know it is getting power as when i unplug from the wall i can hear a noise.
hi;
its sounds like a loose solder or high voltage leak inside your LTV
if you know how to open the back cover or technical experience to troubleshoot
you can check the power supply board and inverter board if it has a loose solder
you can visualize it in the back of the board.
also check the wires connected to inverter boards if it has a leak.
or shorts.
Aug 28, 2011 | Westinghouse LTV-32w3 HD Television
We have a westinghouse lcd 32w3 hd and when we hooked up a hdmi for the first time the screen went black and no picture or sound, how do we fix this?
If everything but the HDMI is working, its a possibility that the source has a compatibility issue or your TV needs a software/firmware update needed
Aug 01, 2011 | Westinghouse LTV-32w3 HD Television
I am having problems with my Westinghouse LTV-32w3 HD TV. If flickers and rolls kind of like the old tube tv used to roll and you would have to adjust it in the back by turning the nob. I have a 37 inch...
The LCD controller is bad, after about on for 30 minutes, see sample here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notee: my pix show the board with the cover removed. You can run the TV with the back open and have s small fan blowing in the back to keep it cool.
You need new LCD controller (there are more than one version, you need to match with the LCD panel): http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Nov 25, 2009 | Westinghouse LTV-32w3 HD Television
Picture blurry on my Westing house LTV-32w3 HD Television
hi possably is the fan in the back make shour it is working all the time that there is no dust bild up on it stops it from spining it may need a cleen ,or it is a transister heeting up and cooling down the transister is on its way out it will be a hard fix for a tech to fined thay will fined it but it will cost you a heep ,its best to whate till its gon completly .cheers peter
Apr 05, 2009 | Westinghouse LTV-32w3 HD Television
Freezes during auto programming
The atsc or qam tuner in your Westinghouse LTV-32W3 HDTV is malfunctioning and needs to be replaced. Unfortunately you will need to purchase a new mainboard since it is integrated. Another option is to return to using an external tuner like your cable box.
Feb 09, 2009 | Westinghouse LTV-32w3 HD Television
Westinghouse Model LTV-32w3 HD goes green with the look of a negative image intermittant. Comcast tech checked it on and off the box. Used our DVD player and same results. Bought it at the Moffet Field...
The "lvds" cable which is connected to the lcd controller board is taped to the backlight housing and is transmitting interference to the controller board. Remove the tape and pull the cable away from the backlight housing slightly. You will have to remove the mainboard to do this since it is underneath it. Do not touch the power supply or power supply connectors (dangerous high voltage).
Jan 05, 2009 | Westinghouse LTV-32w3 HD Television
Picture quality
I had the same problem before. I had my wireless router really close to the tv. I relocated the router, and the problem never came back.
Jun 05, 2008 | Westinghouse LTV-32w3 HD Television
Televison & Video Logo
231 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
