Sorry to say,but if there was an improper wiring,it could fry just about everything/anything.To repair it would be time consuming and probably cost about just as much.Labor for a repair center easily starts at $60/hour,maybe more.Repair centers have a parts price minimum markup of 20%.Unless you have a solder gun and a multimeter and solder to repair yourself,it would be a very wide range estimate considering the circumstances.It could cost $40,it could cost $400.If the display is not working especially and needs replacing,that is quite expensive.If you do have some of the equipment,I could guide you on a few things to check first.Although you say a few circuits,if you do not have the knowledge it may just be 1 circuit really,most likely input power to start with which is 2 diodes to check,then go from there.If you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Good luck,Greg
Good Afternoon friend, that's a great question!
From my understanding your Electrolux range is displaying a code of "d-o". The code could stand for open door, could be missing a sequence, or a miscommunication within the control panel. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue I would suggest having a professional technician out to perform a proper diagnosis and repair. Hope this information is helpful. -Matt
When you used all elements the power supply wire have been
gone to the maximum current absorbed so to the maximum heat. When the cook top
is new it can withstand this heat but due to long time used now you have burned
out wires and probably to junction point. So now the power supply wire is
burned and is open circuit thus not any power to the heater. The wires have
just open circuit and they don't touch each other or the metal body of the cook
top that is why you don't have the circuit breaker fuse to trip off. So now you
need to disassemble the cook top and you will very easily find the burn point
which should be melded and burned black and replace all parts that they have
been burned with new one.
Here is the link where you find the parts layout, the wiring
diagram and also order any parts you might need.
Also just for safety, avoid to use all four heater at the
same time in the future.
