Question about Zenith Televison & Video
I have a zenith/lg lcd projection tv. It's a 44'' .Model # M52W56 lcd / video product E160712. The tv sounds work and the pic and pic 1/2 of the screen work. The screen want show a whole pic just the sound. what could be the problem
    New Friend:
  • 32 Answers
Cheaper to just buy a new tv mate,sounds like the pixels for that half of the screen are gone.
Posted on Dec 04, 2010
6ya staff
SOURCE:
Very dim picture
Ur tv have been in use for at lest 4 or 5 hours a day the last 1 1/2 or 2 year?The projection bulb life it over.Require a new bulb.
May 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
Zenith tv dosen't work
Power supply Board Call UED 1-800-648-6657 or try Encompass 1-800-638-3328
Dec 07, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Jul 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Light Blue Area - Zenith E4446LCD 44
Light engine needs to be replaced. It is a common problem on this model TV. LG covered mine without charge. Contact LG customer support and explain the issue to them.
Apr 02, 2008 | Zenith E44W46LCD 44" Rear Projection...
Growing blue haze on our picture screen.
This is a bad problem with the light engine caused by overheating usually due to reduced airflow from dirty air filters.
My recommendation is to push your warranty company to replace this subpar model with a different one. There are too many instances of repaired models having a reoccurance of this same problem.
The blue line you are seeing is a product of one or two possibilities. The LCD panel which provides the blue imagery, which by the way is made by SONY Electronics, is defective. The LCD panel, in the optic engine (made by Ricoh) is basically loosing partial horizontal data, or the blue color filter has overheated and is becoming discolored, causing the loss of correct deflection through the optic prism. There are two ways to approach this. LG can offer some concessions and get you squared away, or provide the part, and you would be responsible for the service labor involved. Either way it can happen. The first thing I have to suggest to anyone purchasing a LCD or DLP projection TV is REMEMBER to keep an eye on the air intake filters. LG / Zenith products have one in the rear of the set, and 1 on the bottom of the unit. Reduced air flow through these units cause these "video deflection" issues. Overheating plainly affects these sets. I personally wouldn't own one, no matter who made it.
Jan 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith lcd with a yellow dot
CALL LG I HAVE THE SAME PROBLEM WITH MY TV AND THEY EXTENDED MY WARRANTY FOR A NEW LIGHT ENGINE I HAVE HAD MY TV SINCE 2004 AND THEY PUTIING A NEW LIGHT ENGINE FOR FREE IN 2009
Dec 13, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44 in. Rear Projection (Wont Turn on)
I bought an open box unit at Best Buy, it had no remote or manual. Go to http://www.zenithservice.com/, click on owner's manuals, answer the 4 questions using drop down menus and then you can download an owner's manual and save it to your computer/burn it to a CD/print it out. If you choose to print it out, beware, the manual is 60 pages. One of the 4 questions they ask is "Product", choose Projection TV, not LCD TV. The 4th question is "Model Number", mine is E44W46LCD, is guess everyone's here is the same, duh.
For the remote, I looked in the phone book for an authorized Zenith TV repair company. I called them and gave the model number and paid over the phone. I had the remote shipped to my home address. The total including tax and shipping was $50. The remote they sent is a large Zenith mulit-function #6710v00102k. I don't know if that is the remote that would have came with the TV, it worked without having to program it first. It can control TV/VCR/Cable/DVD/Sat. I t has controls for 6 inputs, SAP, mute, Surf, Video, Picture in Picture, Ratio (16:9, 4:3, Zoom, etc), CC, Freeze, Menu, and controls for DVD and VCR (rewind, play, etc). If you can't find a place in your area to get the remote, Email me at gregg@hillscabinet.com and I'll look up where I got mine from. It came from Palm Desert, CA.
I don't know about your TV not coming on, is it plugged in? If it is, that's about all I've got. Gregg
Oct 28, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
133 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
