Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
Posted on Dec 05, 2010
I can't open it - Samsung Tocco F480 - Pay Monthly Cellular Phone
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Dec 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
5221
Points
97
The device could be locked into a password. Reset the password by clicking the options of password reset. A prompt should provide another asking to answer a secret question, once approved makes possible password reset into another code of choice. remember that reseting the password requires establshing another secret code question, that becomes handy whenever a password is lost. On a password lock, the only message displayed should be password related.
2helpful
What will cause a sunroof not to close properly on a 2007 Milan
A lot of thing's , has sensors , switches , a control module , relay's etc....
The roof opening panel is an electronically operated panel that can be opened or closed by pressing a switch located on the overhead console. It also has one-touch open, one-touch close, one-touch vent open and one-touch vent close features.
Roof Opening Panel The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened, closed or tilted by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The roof opening panel has one-touch open and one-touch close features that are activated when the switch is momentarily pressed to the double detent OPEN or CLOSE position. These functions are controlled by the roof opening panel motor/module.
The roof opening panel motor must be initialized whenever the roof opening panel motor has been removed from the roof opening panel system, the roof opening panel assembly has been removed from the vehicle, a new roof opening panel motor has been installed or a new roof opening panel assembly has been installed.
Plus the mechnical parts of it .
Visual Inspection Chart Mechanical Electrical
  • Roof opening panel
  • Roof opening panel frame
  • Roof opening panel drain hoses
  • Roof opening panel lifter assemblies
  • Roof opening panel trough
  • Roof opening panel air deflector assembly
  • Roof opening panel seal
  • Roof opening panel shield
  • Battery junction box (BJB) fuse 33 (20A)
  • Smart junction box (SJB) fuse 12 (7.5A)
  • Circuitry
  • Accessory delay relay
  • Roof opening panel motor and module assembly
  • Roof opening panel switch
tip
Android Keyboard Shortcuts for Browsing Menu + I: Zoom in Menu + O: Zoom out...
<br />Android Keyboard Shortcuts for Browsing<br /><br />Menu + I: Zoom in<br /><br />Menu + O: Zoom out<br /><br />Menu + J: Go back a page<br /><br />Menu + K: Go forward a page<br /><br />Menu + R: Refresh current page<br /><br />Menu + F: Find on page<br /><br />Menu + B: Open bookmarks<br /><br />Menu + S: Open social network sharing menu<br /><br />Menu + H: View browsing history<br /><br />Menu + S: Open browser settings<br /><br /><br /><br />Android Keyboard Shortcuts for Apps<br /><br />Search + B: Open browser<br /><br />Search + C: Open contacts<br /><br />Search + E: Open e-mail<br /><br />Search + G: Open Gmail<br /><br />Search + I: Open calendar<br /><br />Search + M: Open maps<br /><br />Search + P: Open music<br /><br />Search + S: Open text messaging<br /><br />Search + Y: Open YouTube<br /><br />
on Feb 06, 2011 • Google Android
Sunroof will not close. Was working fine earlier today
The roof opening panel assembly uses an integrated motor and module to operate the roof opening panel. The roof opening panel motor and module are installed new as an assembly. The roof opening panel is an electronically operated glass panel that can be opened or closed by the roof opening panel switch. Actuating the switch in either a forward or rearward motion supplies a ground to the roof opening panel motor/module. The soft-stop function is controlled by the roof opening panel motor/module. The roof opening panel has 3 modes of operation, manual mode, express open and tilt. The express open feature is activated when the switch is pressed momentarily. The tilt feature is activated when the tilt switch is depressed. These functions are controlled by the roof opening panel motor/module.
  • Roof opening panel water trough
  • Roof opening panel rear trough guides
  • Smart junction box (SJB) circuit breaker 47 (30A)
  • Circuitry
  • The roof opening panel does not open or close - one direction only
  • Circuitry
  • Roof opening panel motor assembly
  • Go To Pinpoint Test E .
PINPOINT TEST E: THE ROOF OPENING PANEL DOES NOT OPEN OR CLOSE Test Step Result / Action to Take E1 CHECK THE ROOF OPENING PANEL LIFTER ASSEMBLIES FOR OBSTRUCTIONS OR DAMAGE
  • Check the roof opening panel lifter assemblies for obstructions and damage.
  • Are the roof opening panel lifter assemblies OK?
Yes
GO to E2 .
No
REMOVE all obstructions and REPAIR any damage. If lifter assemblies cannot be repaired, INSTALL a new roof opening panel frame. REFER to Roof Opening Panel Frame in this section. TEST the system for normal operation. E2 CHECK THE ROOF OPENING PANEL WATER TROUGH AND REAR TROUGH GUIDES
  • Check the water roof opening panel water trough and rear trough guides for any loose obstructions.
  • Are the roof opening panel water trough and rear trough guides installed securely and free from obstructions?
Yes
GO to E3 .
No
REMOVE all obstructions from the roof opening panel water trough and install securely. SECURE the rear trough guides or INSTALL new roof opening panel rear trough guides if damaged. REFER to Roof Opening Panel Rear Trough Guide in this section. TEST the system for normal operation. E3 VERIFY THE ROOF OPENING PANEL ADJUSTMENT
  • Verify the roof opening panel is adjusted correctly.
  • Is the roof opening panel adjusted correctly?
Yes
GO to E4 .
No
ADJUST the roof opening panel. REFER to Roof Opening Panel Alignment - Horizontal Adjustment and Roof Opening Panel Alignment - Height Adjustment in this section. TEST the system for normal operation. E4 CHECK THE ROOF OPENING PANEL MOTOR/MODULE FOR INITIALIZATION
    NOTE: The roof opening panel motor initialization procedure must be done when repairs are carried out on any part of the roof opening panel assembly, including whenever the roof opening panel motor/module has been removed from the roof opening panel assembly, a new roof opening panel motor/module has been installed or when a new roof opening panel assembly has been installed. Refer to Roof Opening Panel Motor Initialization in this section.
  • Carry out the Roof Opening Panel Motor Initialization procedure. Refer to Roof Opening Panel Motor Initialization in this section.
  • If the concern still present?
Yes
GO to E5 .
No
The system is operating correctly. The roof opening panel motor/module was uninitialized. E5 CHECK THE POWER WINDOWS
  • Key in ON position.
  • Verify the power windows operate.
  • Do the power windows operate?
Yes
GO to E6 .
No
REFER to Section 501-11 to diagnose the accessory delay relay circuit. E6 CHECK THE ROOF OPENING PANEL SWITCH
  • Carry out the roof opening panel switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Did the roof opening panel switch pass the component test?
Yes
GO to E7 .
No
INSTALL a new roof opening panel switch. TEST the system for normal operation. E7 CHECK CIRCUIT CBP47 (GN/BU) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Roof Opening Panel Motor/Module C922.
  • Measure the voltage between roof opening panel motor/module C922-4, circuit CBP47 (GN/BU), harness side and ground.
  • Is the voltage greater than 9 volts but less than 16 volts?
Yes
GO to E8 .
No
VERIFY the smart junction box (SJB) circuit breaker 47 (30A) is OK. If OK, REPAIR the circuit. TEST the system for normal operation. E8 CHECK CIRCUIT GD143 (BK/VT) FOR AN OPEN
  • Measure the resistance between roof opening panel motor/module C922-3, circuit GD143 (BK/VT), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to E9 .
No
REPAIR the circuit. TEST the system for normal operation. E9 CHECK CIRCUITS CPR37 (YE/GY), CPR39 (VT/WH) AND CPR40 (YE/OG) FOR AN OPEN
  • Disconnect: Roof Opening Panel Switch C930.
  • Measure the resistance between the roof opening panel motor/module C922-1, circuit CPR40 (YE/OG), harness side and roof opening panel switch C930-8, circuit CPR40 (YE/OG), harness side. Measure the resistance between roof opening panel motor/module C922-2, circuit CPR39 (VT/WH), harness side and roof opening panel switch C930-11, circuit CPR39 (VT/WH), harness side. Measure the resistance between roof opening panel motor/module C922-5, circuit CPR37 (YE/GY), harness side and roof opening panel switch C930-14, circuit CPR37 (YE/GY), harness side.
  • Are the resistances less than 5 ohms?
Yes
GO to E10 .
No
REPAIR the circuit. TEST the system for normal operation. E10 CHECK FOR CORRECT ROOF OPENING PANEL MOTOR/MODULE OPERATION
  • Disconnect the roof opening panel motor/module connectors.
  • Check for:
    • corrosion.
    • pushed-out pins.
  • Connect all roof opening panel motor/module connectors and make sure they seat correctly.
  • Operate the system and verify that the concern is still present.
  • Is the concern still present?
Yes
CHECK the jumper harness between the vehicle harness and the roof opening panel for open or shorted circuits. If the jumper harness is not OK, INSTALL a new jumper harness between the vehicle harness to the roof opening panel motor/module. Otherwise, INSTALL a new roof opening panel module/motor. REFER to Roof Opening Panel Motor in this section. TEST the system for normal operation.
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. TEST the system for normal operation.
1433helpful
16answers
I want open new 2go account
I Want to open mew 2go account
1helpful
I cant' open the facebook homepage
If you can access other websites aside from this follow these steps:
1. Open Control Panel, then Internet Options, then open General tab and delete browsing history.
2. Open again, www.facebook.com.
3. If it won't open still. Check if you have proxy, if there is, remove it.
4. Open again, www.facebook.com.
5. If it won't open still. Reset your browser, Open Control Panel, then Internet Options, then open Advanced tab and press the reset button.
Try open facebook again.
3helpful
2answers
What is code 14 on 03 zx636
Hi, here you go:
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank Key detection
39 ECU communication error
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
83 Oxygen Sensor #2 inactivation, wiring open or shout (Equipped Models)
94 Oxygen sensor #1 malfunction, wiring open or short (Equipped Models)
95 Oxygen sensor #2 malfunction, wiring open or short (Equipped Models)
1helpful
4answers
Sun roof will nt close cant find the rite fuse
check fuse F1.401, 30 amp in central junction box (in truck). Check your owner manual for fuse information.
Headliner must be removed to access motor.
  • Circuitry
  • Roof opening panel adjustment.
  • Battery junction box (BJB) fuse.
  • Circuitry.
  • Roof opening panel switch.
  • Roof opening panel motor assembly.
  • Roof opening panel lifter assemblies.
  • The roof opening panel does not open or close — one direction only
  • Circuitry.
4answers
Can u help us m8
contact the dealer of where you bought your stereo...or maybe the sony company...:)
2answers
I pluged the radio in me car an it says code in before itl work i got it off a friend an he had it workin in his car before i tuck it ou an he said e lost the code he only used the code once an didn n
You need to enter the code using the remote. Try these codes.
You need to press reset after each attempt.
CODE 1: MODE SOUND OPEN ATT
CODE 2: ENTER OPEN meNU 6
CODE 3: OPEN DISC+ 1 LIST
CODE 4: SEEK- SEEK+ 3 OPEN
CODE 5: OFF 4 OPEN SOURCE
CODE 6: 2 OPEN DSPL SOUND
CODE 7: OPEN 5 ATT SEEK+
CODE 8: DISC- DSPL OFF OPEN
CODE 9: SEEK+ SOUND OPEN ENTER
CODE 10: DISC- LIST SEEK- OPEN
CODE 11: OPEN 4 LIST OFF
CODE 12: DSPL SOURCE OPEN 1
CODE 13: MENU 2 MODE OPEN
CODE 14: 5 DISC+ OPEN ATT
CODE 15: 3 MENU SEEK- OPEN
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
