No!! I don't need another copy of the manual because the manuel written incorrectly. I need to know how to set the watch.
Thanks,
Art Peel
Okay.. please wait..
what exactly the model# of the watch..
thanks
micro
just keep cycling through after you set time:
If not in the time mode, press mode to get to the time mode.
While in the time mode, press and holdlap/rst for two seconds.
The seconds will begin to blink.Press st/stop to reset seconds to zero
Press mode and the minutes will begin to blink.
Press st/stop to advance the minutes
Press mode and the hour will begin to blink.
Press st/stop to advance the hour
Press mode and the day and date will appear. The day will blink.
Press st/stop to advance the day.
Press mode and the month will begin to blink.
Press st/stop to month the minutes.
Press
lap/rst to return to normal state with you new settings. You can hit
lap/rst to return to normal state at any time in the process, for
example if you only want to set the minutes, just hit lap/rst after you
set the minutes.
you should identify the exact model of your watch, there's so many monte carlo watch with a blue strap, which i don't which one did you have...
And please don't rate, when the final solution was not made..
Thank you for using fixya.
8574 is the model number
This solution is not correct for my Montres Carlo/Blue/ Rubber/watch. I'm not sure what the Time Mode looks like. When I press the Mode button the first thing that comes up is "ALM".
then "1:09" , then "STP", then "0'00''00" then "LON", then "10:20T2". None of the sequence of events listed works. Maybe these numbers on the watch box will help to identify the watch:
SKU #29040-004
Lot # PW-21519
Thanks,
Art Peel
I sent the watch to a repaireman. Your solutions did not work.
