Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Connecting to Dish Network receiver/tuner
I currently own a 42" Westinghouse plasma tv which does not have a built in tuner. It works fine connected directly to the Dish Network receiver/tuner. Can the 22" Westinghouse lcd monitor work the same way. It has VGA, DVI and S-Video inputs.
  • 405 Answers
Yes!
Posted on Jun 27, 2008
Anonymous
SOURCE:
Have Sanyo DP50740 Plasma tv and Dish Network receiver. This morning I turned TV on and receiver on and Black screen appeared on TV with floating no signal box with white letters. I do not have the t
Check the TV first by tuning it to an external RF source; ie; on-air program by connecting it to external Ariel and make sure that the TV is OK. If the TV works fine with on-air program, the Dish Network receiver is either fault, of it do not get input signal.
Oct 18, 2014 | Televison & Video
How do I connect my LG TV to my dish network
Hello Al, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your LG TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your LG TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
Dec 31, 2011 | LG 42PG20 42 in. Plasma HDTV
Every morning when i turn on vizio tv,i have no volume..Have to turn off & on about 10 times...Worked perfectly fine,day before with direct tv box...Dish box,no
In order to best assist you I will need a little more information. Have you tried checking the cables running from the receiver to the TV? Are there any devices connected between the receiver and your TV? Also what type cables are connecting the receiver to the television?
Daniel Busa
DISH Network
Customer Service
Mar 18, 2011 | DISH Network IR Remote Control
I have the dish network box which is HD although I can get a video feed on the television I get no audio
The first step you want to try is unplugging the receiver for ten seconds. After that check the cabling if you have component cables (red, blue, green, red, white) make sure the red and white are connected firmly. Also make sure they are connected right next to the red blue and green cables on the back of the TV. If you have an HDMI cable try connecting it to another port on the back of the TV. If that fails try replacing the cable.
Daniel Busa
DISH Network Customer Service
Jan 30, 2011 | Samsung PPM42S3 42 in. Plasma Television
I have dish network and am trying to watch tv on my gateway plasma. how do i connect my satelite cable to plasma to get picture?
We would like to guide you through the connection process,but depending on what kind of receiver and TV you have this process may vary.Visit our "How to connect receiver" page here:http://www.dishnetwork.com/SupportSection/setup-receiver.
Once we have everything connected correctly, check what channel or input yourTV is currently on by powering the TV off then back on and noting the channelor input that appears on screen when the TV is powered on.
Steps for getting picture on TV1:
If you are using a Coax Cable to connect the receiver to TV1, check thereceiver's back panel for the output name. If your receiver has a "TVCH 3/4 out" (non-ViP Receiver): Tune TV to channel 3 or channel4, if it has "Home Distribution" output (ViP Receiver):Tune TV to channel 62 or 75. If using non-Coax (RCA,Component, or HDMI) to connect receiver to TV1, cycle through the inputs untilpicture appears (this information may appear on the remote sticker), mostTVs have a "TV/Video", "Input", or "Source" button.
Steps for getting picture on TV2:
Access "Modulator Setup" from TV1 by pressing "menu"then 6-1-5. Tune TV2 to the channel that appears under "TV2 Out" onscreen. If still no picture, change the "TV2 Out" mode fromAir to Cable, or if it's already on Cable, change it to Air. Then change thechannel of TV2 to what is now displayed under "TV2 Out".
If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. It may take up to 5 minutes for the reset processto be completed. If you still are not getting a picture, connect anothercomponent (VCR, DVD Player, etc.) to the same TV, using same cable, same input,and same channel to see if it works. If it works give us a call at1-800-333-DISH (3474) for additional troubleshooting, if you don't get apicture with the other component, replace the cable.
Hope this steps help, and thank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Service Representative
Dec 02, 2010 | Gateway GTW-P42M303 42 in. Plasma...
The sylvania plasma tv does not have a coaxial cable connection, how do I connect my local cable?
You just can't. Not without an external receiver.
Your TV is simply missing a piece of hardware - it is called TUNER - that can understand the signal that runs through the cable (or an antenna) and decode it into simple video signal.
So the only solution is to buy an EXTERNAL TUNER device (also called external receiver or external set top TV box).
Those are rather cheap compared with what they used to be, but if you care for an advice from professional it is: sell your TV and use the revenue towards the purchase of a new one. All TVs currently in the mainstream sales channels have that thing built-in.
Some of the older models that you will find on Craigslist (like yours) do not.
it is usually not a problem for users with cable TV because most cable TV boxes also have a built-in tuner. If you are talking about how to connect your TV to your local cable company then the right thing to do is call your cable operator and tell them you want a newer receiver that outputs standard composite (one yellow one red one white) or component (green, blue, yellow and white and red) - if your TV has the later.
Hope this helps. If it does please rate accordingly.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Plasma
When you say "struggles to get a signal" I assume you are receiving HD programming over the air using HDTV antenna. If so, try to re-orient the antenna. Better yet, go to this website http://antennaweb.org
type in your address and it will provide you with the best antenna and antenna positioning based on your location.
If you are receiving HD programming via cable or dish, contact your service provider and they can best resolve your issue if the problem is beyond the loose cable connection in your TV's tuner input.
FixYa!
Jul 08, 2008 | LG 42PX5D 42 in. Plasma HDTV
Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Mar 13, 2008 | LG 42LC2D 42 in. LCD HDTV
Transparent horizontal bar
disconet the ground on the power cord of your tv will fix the problum. or the subwofer power ground .
May 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
531 people viewed this question
Top Westinghouse Computers & Internet Experts
ByRuss
Level 1 Expert
Ekse
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
