Kodak Easyshare M753 Digital Camera Logo
Posted on Jun 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen has lines
I put my camera on the easy share printer/charger,now my screen has lines.The colors of the lines are line a blue and red/pink.
Arcadian Duran
Level 2:
Sergeant:
  • Expert 284 Answers
  • Posted on Nov 03, 2008
Arcadian Duran
Expert
Level 2:
Sergeant:
Answers
284
Questions
0
Helped
78450
Points
643
Most likely youve damage the lcd screen either by dropping it even though you didnt, but that would be the only cause this problem, line on a lcd screen are usually cause by a broken power current thru screen or a cracked lcd screen maybe it was defective in the first time. I dont know, but line are usually means no power or no information going thru screen.
need to be replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
2helpful
Kodakeasy share v1233, Some times when I go to take a picture the screen goes pink and there are lines through the screen, and a Captial AF in brown comes up. It does not do this all the time, but it
Hello Cathy, The "AF" means auto focus, The pink screen and the lines are a camera fault, you are going to need the camera checked to see what the internal problem is, it is not something that you are doing wrong, it is the camera.
Best Regards, Russell
I have a Gestetner DSc38u and when I print colour I get a 'red'/'pink' line about an inch from the top of each page. Any suggestions?
If the line is only red or pink, it is most likely caused by the magenta PCU. Replace this PCU and your problem will go away.
Occasionally the magenta developer unit can cause a red or pink line, but the problem is more than likely from your magenta PCU. The PCU is easy to replace, and instructions will come in the box if you order an OEM replacement unit.
Camera screen registers color dots and lines only
Googled until I found others with same problem with this particiular camera - then researched the proper address to send the camera to for repair - after calling to make sure they would still repair the camera.
5helpful
2answers
What is the color coding of the connectors in SB Audigy 2 ZS video card?
red/pink is microphone in
green is line out to powered speakers, external amp or headphones
blue is line in
black is rear speaker out to powered speakers or ext. amp
yellow/gold is digital out to SPDIF/DAT
color code is known as the PC99 standard
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Rainbow colored lines on screen.
Something kind of like that happened to my camera, I just had to send it back, and they said that the LCD screen was cracked. :]
Screen just flashes horizontal pink & blue horizontal lines when you turn it on
It sounds as though you may have a faulty lcd. Replace lcd(screen) and see if it solves the problem
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
