SOURCE: i am trying to connect my mackie 1604 into my m
Using two balanced lines either TRS or XLR depending on what is on your M audiointerface, connect the L and R main outputs of the mixer to the L and R inputs of the M Audio. You will need recording software on your computer.
SOURCE: I cant get my mackie
check your cables, on some Mackie boards press the switch to enable master out, make sure the mute or cancle button is not pressed. i have a 2404 vlzpro mixer it's simular to yours, if you have any problems, you can call Mackie direct if the issue is not solved, it could be a bad button, fuse or slide controle, or even a fuse
SOURCE: i have a mackie 1220i onyx mixer, but i cant get
What is the setup you are using. What mics (make and model). What are the settings for the channels? With this info, I should be able to assist.
Please update this.
Thanks,
Dan
SOURCE: I have a mackie 12 channel mixer, but don't
Just use balanced audio interconnect cables (XLR or TRS) between the mixer and the M-Audio interface.
for the software
http://www.mackie.com/products/tracktion...
