SOURCE: Sony TV KDL-32L4000 Turns Pink
My Sony tech says it's most likely a bad cable box. Try a DVD and if the DVD is fine then it's for sure your cable box. Needs to be replaced by the cable company.
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
