Westinghouse SK-26H520S 26 in. LCD HDTV Logo
Anonymous Posted on Dec 06, 2010
I pressed the menu button on my remote control went to channels went to antenna scan and lost all my channels how do I rectify this problem?
Anonymous
Level 2:
  • Expert 126 Answers
  • Posted on Dec 06, 2010
Anonymous
Expert
Level 2:
Answers
126
Questions
Helped
38143
Points
359
Go back to the menu and do a channel scan for cable or if you have a cable box connected change to the input the cable box is connected to with the SOURCE or Input button
1helpful
Cannot scan for channels on remote
The remote model number doesn't help directly. This remote controls several Sanyo TVs including the DP46142 and DP32242. Manuals Lib has the owner's manual (copyright 2012) here: https://www.manualslib.com/products/Sanyo-Dp46142-77711.html . Press Menu (below and to the left of the arrow keys). Select Setup (the icon that looks like a satellite dish) using the left/right arrows. Press the down arrow and go to ANT/Cable setup. Press OK (in the center of the arrow keys). Use the left/right arrow keys to make sure that the Ant In line is set to Antenna. Press OK. Go down to Auto Setup and press OK. Choose from All Channels, Analog Channels and Digital Channels and press OK again. Select Apply and press OK when the scan is finished. (All channels and Digital Channels will work the same way since most analog channels are no longer broadcasting.) See https://www.manualslib.com/manual/306779/Sanyo-Dp32242.html?page=22#manual . Note: digital channels will not display if the signal strength is low. You may need a different antenna or a different antenna placement. See antennaweb.org or tvfool.com for suggested station transmitters.
I hope this helps.
(note: the physical buttons on the TV should work to navigate the menu. Use the channel buttons for Up/Down and volume for left right. The OK button is the Input button.)
How do I scan the TV clc501 for channels? I don't see a button for (antenna) to scan channels. I am only getting 2 channels, any help would be appreciated.
I can provide some general steps on how to scan for channels on a TV: Make sure that your TV is connected to an antenna or cable input. Turn on the TV and go to the main menu or settings. Look for an option to scan for channels or auto-tune. This option may be labeled as "Channel Setup" or "Channel Scan." Select the option to scan for channels and wait for the TV to complete the process. This may take several minutes. Once the scan is complete, you should see a list of available channels on your TV. If you're still having trouble, I suggest referring to the user manual that came with your TV for more specific instructions. Alternatively, you can try contacting the manufacturer's customer support for assistance.
HOW DO I PROGRAM BRIVIAL SONY TV
To program a Sony TV, you will need to follow these steps:
  1. Press the "Menu" button on your remote control.
  2. Use the arrow buttons to navigate to the "Settings" menu, and then press the "Enter" button.
  3. Navigate to the "Installation" or "Setup" menu, and then press the "Enter" button.
  4. Select "Programming" or "Channel Setup," and then press the "Enter" button.
  5. Follow the on-screen instructions to scan for available channels. This will typically involve selecting your cable or antenna source and then initiating the scan.
  6. Once the scan is complete, use the arrow buttons to navigate through the list of channels and select the ones you wish to keep. Press the "Enter" button to lock them in.
  7. Exit the menu when you are finished.
Note that the specific steps may vary depending on the model and software version of your Sony TV. You may refer to the manual of the TV to get more information.
Vizio d-series 32" smart tv find channels using my antenna
On the remote, press the "MENU" button to go to the "Menu" screen, select "TV Settings" with the arrow keys, and press the "OK" button. Then go to "Device Setup" and press "OK". Go to "Input Source" and press the arrow keys until "Antenna" appears, then press "OK".
Select the "Tuner" option and press "OK". You may see an option to scan channels. Select it and press "OK". The TV will scan both analog and digital channels and can take an hour to scan all. Just wait and watch the "Found channel" count. If it does not increment, your antenna may be bad or not connected correctly.
The Vizio tuner is good enough to find over 14 digital channels with a cheap $10 flat digital antenna taped to my window.
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Can get only 1 channel to program on my toshiba
hi if the tv has dtv just select air digital only thanks
shaun
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
2answers
I hook my antenna to the back and I'm not receiving a picture
I'm assuming your Antenna is connected to your TV with a co-axial cable? If so, please make sure you have run the Analogue/Antenna/Air channel scan correctly:
1. Switch the TV on
2. Press the "MENU" button on the Curtis remote supplied with the TV.
3. Press the RIGHT arrow button five times to highlight the "Channel" menu
4. Press the "ENTER" button or the DOWN arrow once to open the "Channel" menu
The Air/Cable option should be highlighted.
5. Use the LEFT/RIGHT arrow buttons to set the "Air/Cable" option to "Air"
6. Press the DOWN arrow to highlight "Auto Scan"
7. Press the "ENTER" button or the RIGHT arrow once to start the automatic channel scan.
When the scan has finished, the TV should automatically return to viewing mode. If not, just press the "EXIT" or "MENU" button on the remote to close the menu.
You also need to make sure the correct INPUT/SOURCE is selected on the TV:
1. Press the "SOURCE" button on the Curtis remote
2. Use the UP/DOWN arrows to highlight "TV" in the INPUT SOURCE menu
3. Press the "ENTER" button on the remote to select "TV" and close the INPUT SOURCE menu.
This should be all you need to do to watch your TV from an antenna source.
Please post back if you are still unable to get it to work and need further assistance.
Regards,
BElectric
3answers
I pressed the menu button on my remote and went to channels then I went to antenna scan and lost all my channels how do I rectify this problem?
just go to menu and choose turbo/maunal search or go to channels and press right arrow key on your remote it will revert back to its previous settings
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
