It only hands out private ip addresses. they typically start with 192.168.x.x.
in the setup of router make sure and change all default values for Administration (router username/password) and also change the default IP Address of router to whatever you like, e.g router ip can be 192.168.1 - 249.1
Your surfing is only private when you're using SSL (https) connections between your browser and the website[s], no matter what route[s] your internet connection takes.
You need to configure the router for internet access. If you are on Cable ISP, you need to do MAC Cloning. If you are on DSL ISP, you need to configure the router for PPPoE. Normally, the router's setup CD can guide on how to do it.
A public IP address is usually assigned to the WAN port (outside/public side), which is how your router is conected to your Internet provider service.
A private IP is always assigned to the private network side (LAN = Inside). Unless you are hard coding your IP addressing on each of your devices, you will need to have DHCP enabled in your router with enough user IPs for your devices (more than 1).
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
