Question about Samsung S3650 Corby / S3650 Genio Touch Cell Phone
I WANT THIEM - Samsung S3650 Corby / S3650 Genio Touch Cell Phone
How to lower the spare tire?
on most of thiem there is a hatch right behind the front seats on the floor look around see if u see were little piece of the carpet folds back u will see a bold loosen it to lower tire
Apr 21, 2010 | 2000 Toyota Sienna
2001 Chevy Silverado Ext Cab airbag light won't turn off
umm not sure on the 02 but sounds like u are looking at the passengers side air bag light when that lights on means there is a problem with it and its not working so if its off that would be the problem and the reason it turns on some of thiem have a x2 symbol on thiem to let u know its the passenger side
Mar 24, 2010 | 2001 Chevrolet Silverado 1500
Motor problem in 1988 Mazda 323 Hatchback
depending on what it is internally if thats the problem then id say no its not worth fixing cost more to rebuild or replace the motor than what its worth used motors getting hard to find for older cars due to thiem bieng crushed at junk yards already
Mar 24, 2010 | 1988 Mazda 323 Hatchback
Guages do not work all fueses are good speedo and tach do not work also
gm has had alot of problems with there instrument cluster of the last few years best bet it to take to your local dealer they proubley can fix under warranty or goodwill it to u they put a new cluster in to fix thiem
Mar 24, 2010 | 2006 GMC Sierra 3500
Jaguar x type handbrake adjustment
car has 4 wheel disc brakes take off the rear pads and rotors u will see a set of shoes on the inside of that adjust thiem up and u should get alot more hand brake
Mar 16, 2010 | 2002 Jaguar X-Type
Cant find the fuse for my cigarette lighter in my x reg focus ghia
The fuse is going to be in your fuse box. On the diagram it should show either cigarette lighter or accessories. It is there you will find the fuse.
Mar 15, 2010 | 2000 Ford Focus
Ran my sportage out of oil. cleaned out engine
top the oil off clean the motor of any oil thats on it take to the dealer car should steal be under warranty let thiem fix it for free
Mar 15, 2010 | 2006 Kia Sportage
2002 nissan altima will not accelerate past aobut 5 miles per hour and the tranfluid is full
they had some problems with the throttle bodys on thiem could be the couse if the check engine light is on will need the codes taken out to be sure
Mar 14, 2010 | 2002 Nissan Altima
I like doing my repairs DIY. How do i change the spark plugs on my 98 grand cherokee
u will have to look on the side of the motor and unbolt the coil strip thats down the side of it once u unbolt it and move it out the way the spark plugs are right there if u have v8 u will see coils over each cylider just remove thiem one at a time and replace the plugs
Mar 14, 2010 | 2004 Jeep Grand Cherokee
Lines on some pictures
This is a failing processor. Check out repair costs from Nikon A new camera may be the better bet.
Aug 11, 2007 | Nikon COOLPIX L3 Digital Camera
Samsung S3650 Corby / S3650 Genio Touch Cell Phone Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
