SOURCE: 3.0 h.p. wet/dry vac
Check the motor brushes, either worn down or dust is keeping one of them from laying on the armature. The other would be a bad motor.
SOURCE: 177611 wet/dry vac
Either you aren't getting the top on correctly so it will latch, or there maybe a problem with the latches. You should have a one year warranty on this, take it back to Sears and have them look at it.
SOURCE: craftsman wet/dry vac
It is supposed to have a round plastic plate and a plastic handle with a nut made in it that tightens against the plate to hold the filter on
SOURCE: I do not have my
no - simply remove the filter. That is the only step necessary!!
Hope your cleanup goes well!!
Thanks for using FixYa - a FixYa rating is appreciated!!
