Expert
- Posted on Dec 06, 2010
Re: Ok, well me and brother want to play Wii. But we only...
- Check to make sure the Sensor Bar cord is inserted into the back of the Wii
console and the Sensor Bar is centered above or below your TV screen (more
info).
- Make sure you are using fresh batteries in the Wii Remote.
- The Wii Remote Controller should be used between 3 to 10 feet from the TV.
- Make sure no objects are blocking the signals between the Sensor Bar,
the Wii console, and the Wii Remote.
- Check for interference from infra-red light sources, such as candles,
sunlight, fireplaces, and stoves.
- Radio frequency interference may cause the Wii Remote to work erratically.
Check for wireless devices such as cordless
phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
or if the remote lights up briefly than goes out try this
Try these steps!
- Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds.
After a few seconds have elapsed, plug the cord back into the wall
outlet.
- Turn the power of the Wii console ON. When you see the
Health and
Safety screen, open the small flap on the front of the Wii
console to find a red button labeled "SYNC." Press and hold the
SYNC
Button down for 15 seconds. This will clear all the syncs on the
Wii, allowing you to get a clean start to begin the process described
below.
- After holding the SYNC Button on the Wii console down for at
least 15 seconds, you can now "re-sync" your Wii Remotes:
- With the first Wii Remote you wish to sync, remove
the battery cover on the back of the Wii Remote to find a small red
button just below the batteries.
- Press and release the small red button just below the batteries on
the Wii Remote; the blue lights on the front of the Wii Remote
will blink.
- Quickly press and release the red SYNC button on the inside of the
white flap on the front of the Wii console (picture).
- When the Player LED blinking stops and stays lit, the syncing is complete. The LED
that is illuminated indicates the player number (1 through
4).
- This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote
added to the system.
If you are still unable to get the Wii console to recognize your
Wii Remote(s) after carefully following the steps above, please call
1-800-255-3700 for further assistance. [nintendos help line]
i hope this helps you and please vote for me
