Press FUNCTION to select the time. Press FUNCTION until the time appears in the display. 2 Select the portion of the time display you wish to set with 2/3. Pressing 2/3 will select a portion of the clock display: HOUR-MINUTE As you select portions of the clock display the portion selected will blink. 3 Select the correct time with 5/?. Pressing 5 will increase the selected hour or minute. Pressing ? will decrease the selected
hour or minute.
http://www.generalmanual.com/Players/Pioneer-DEH-P4400-Single-CD-Player.htm
SOURCE: wire codes for a pioneer deh-p4400
right rear- purple wires
left front- white wires
right front- gray wires
left rear- green wires
BLACK STRIPE NEGATIVE ON ALL
red- 12volts switche
black- ground
yellow- 12volts constant memory
SOURCE: set clock on Pioneer DEH-P4400
I GUESS, YOU DON'T HAVE OWNERS MANUAL. I RAN INTO THE SIMILAR PROBLEM, HAVING THE MANUAL ON HAND. YOU MUST BE VERY PATIENT: THERE IS A SEQUENCE OF MOTIONS TO SET THE CLOCK: THERE ARE COUPLE BUTTONS, I.E: SEL(ECT), ADJUST(VOLUME CONTROL) OR +/- BUTTONS. USUALLY "SEL" MUST BE HELD FOR A FEW SECONDS, THEN YOU SCROLL TO FEATURE : BASS, TREBLE, LOUD, ETC. USE VOLUME OR SCROLL BUTTONS TILL YOU REACH "SET CLOCK." SOMETIMES: + CHANGE HOUR, - CHANGE MINUTES. AND SO ON. BUT: GET OWNERS MANUAL, IF POSSIBLE. OTHERWISE, IT WILL DRIVE YOU CRAZY AND TIME CONSUMING.
TRY "GOOGLE"
http://audio.manualsonline.com/manuals/mfg/pioneer/dehp4400_dehp44.html
GOOD LUCK,
ALEX'S TV.
SOURCE: need wire diagram for pioneer deh-p4400 car sterio
Need wiring diagram for a pioneer DEH-P4400 car stereo.
display.
display:
HOUR-MINUTE
3 Select the correct time with 5/∞.
minute. Pressing ∞ will decrease the selected
hour or minute.
