Panasonic Pt-50LC13 . On the ballast on the upper right there is 4 wire connection marked p1305 and a white outline with a 1 and a 4.the wires are yellow, red brown and orange.I broke the connector and need to know what order the wires belong
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Yes,it will resolved ur tv picture issues.This tv the projection lamp has not been replaced at least 1 1/2 or 2 years right?The tv on an in used at 4 or 5 hours a day right? The projection lamp life span are over.Sometimes the Ballast board have to be replaced too.This Ballat board it to help to ignite the projection lamp.
Its actually called a ballast its the board that the lamp hooks up to should be easy to find, if you make a mistake though you can get a very nice discharge and it will hurt!
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it. If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Power on the set, listen for afaint buzzing sound as the set tries to fire up. If you do not here it then your lamp driver, or ballast is most likely faulty. Also make sure you have the door and all covers back in place and secure. And make sure you insatlled an orginal panasonic lamp because some generic will not work.
