It can be power supply failure due to bad caps, or it detects shorted circuits in the set so it goes into shutdown mode.
Look at the power supply first for any bad caps, burnt components, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
My EWD1477 was doing this a year ago and I fixed it. Then it started
doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry
sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn
the machine to off with the Program Selector Dial. Then turn off the power at
the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button
should be flashing and the green lights on for Prewash/wash, Rinses and
Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty
any excess water. Press it again immediately after you hear water flowing into
the machine OR two audible clicks. The machine is now in pause mode with the
green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash
button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause
button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing
into the machine and the three green lights mentioned above are back on, turn
the Program Selector Dial back to off, wait 10 seconds, and repeat the process
above.
Step 5: If when you then turn the Program Selector Dial to
Whites/Intensive and hear the two audible clicks, immediately press the
Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then
press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
