Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Can't slide the deli drawer back under its horizontal slider support flat glass platform holder. It just goes in so far and then seems to get stuck. I don't want to force it. What is the proper procedure that I am overlooking to slide this all the in , and then be able to slide it out to the "stop".
6ya staff
SOURCE:
Anonymous
SOURCE: deli drawer
Dear Master Tech: The model number is GLRT13TEB3. The problem is every time you try to open the deli drawer it falls straight down.
It is as if the tracks to hold it are too far apart? Also the tracks are part of the glass shelf.
Any help with this annoying problem would be much appreciated.
Thank-you, Nanc T.
Posted on Feb 17, 2008
Anonymous
  • 117 Answers
SOURCE: I would like to order
repairclinic.com
Posted on Aug 02, 2008
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: GE Profile side by side...water collects under the
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Oct 27, 2009
DRD
  • 76 Answers
SOURCE: deli drawer freezing food
The temperature in the section or the refrigerator isn't set correctly.
Also, check the thermostats if it is functioning correctly. PLEZE LET ME KNOW.
Posted on Sep 17, 2012
shelley garcia
  • 12 Answers
SOURCE: Took our deli drawer to clean. Can't reassemble. Help
If it's the deli drawer from the bottom of you refer and you took the entire assembly out at once you will know because it all came apart when you started cleaning it. If it's got two drawers then you now have a piece of glass a frame with legs on it and two drawers. So open the refer all the way, look at the back and the sides where you removed it from, you'll see some groves or ridges or little nubs take the frame by its self and fit it into those places you see, then take the drawers one at a time ( usually the one closest to the door hinge is best to start) and slide them back into place. take your time because like a dresser drawer there is a notch that you will have to work with that's designed to keep you from pulling it completely out when you open it. then place the glass into the frame on top and your done.
Posted on Oct 02, 2012
My stove drawer is stuck and it won't close or come out , what to do ?
drawer is stuck Anon, Pick up on drawer as far back as possible with some force,shake it up and down, this should allow you to lift drawer from track/slides. Clean and lubricate all wheels, bearings and track/slides and reinstall drawer.
HELP bottom oven drawer stuck on new GE range
How to Open an Oven Drawer That Is Stuck eHow
How to Unstick Oven Drawer
Stove Drawer Stuck or Jams DIY fix
Apr 02, 2016 | Kitchen Ranges
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
Will the deli drawer work properly without the glass door/lid? The pin broke off the right side and can't be fixed ... plastic broke off the actual drawer roller on the right. Cheap plastic ... disapp
Call in a repair man, it shouldn't cost that much. Yes, your food will be effected without that plastic door, as the drawer has controls and cold settings just for deli items. You need a special glue for cold. I'd call in a repair man, or order a new drawer replacement from the manufacturer.
Dec 01, 2014 | Maytag Refrigerators
Need to remove deli drawer
Hi there, it should pull straight out, you might need to get someone with a bit of strength to help you.
If I could I would duck over in a jippy !!
Jan 07, 2014 | KitchenAid Refrigerators
Oct 02, 2012 | KitchenAid Refrigerators
I purchased whirlpool GX5FHTXVA and there is a divider piece of plastic taped to the bottom of deli drawer, I have no idea where it goes. It is not in the manuel.
The wider end of the piece can be hooked anywhere on the back of the deli drawer. Keep the piece bent when you install it or it will scratch the glass on the front of the drawer. Also, make sure the tip of the smaller end is touching the bottom of the drawer before straightening the divider._1165.jpg
Apr 17, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
I cannot get the drawer to close completely on my Jura E8 in order for the "missing drawer" light to go off. I've unplugged the unit to allow chip to reset... nothing. I think the elevator is...
I have the same machine and this seems to happen if the grounds bin is pulled out before it goes through a full cycle. take both the grounds and water trays out. Try to fit the grounds bin around the "elevator", slide the grounds tray underneath that then the water tray as well. It should slide right in then the machine will complete the cycle and work just fine :)
Feb 06, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Deli drawer
Thank-you, Nanc T.
Feb 14, 2008 | Refrigerators
Sliding drawer in the top refrigerator section
hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
Feb 10, 2008 | Sub-Zero 700TC Bottom Freezer Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
148 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
