https://m.blog.naver.com/PostView.nhn?blogId=mobile_app_top&logNo=220570562627&proxyReferer=https://translate.googleusercontent.com/translate_p?hl=en&prev=search&sl=ko&u=http://m.blog.naver.com/mobile_app_top/220570562627&depth=1&rurl=translate.google.com&sp=nmt4&xid=25657,15700022,15700186,15700191,15700256,15700259&usg=ALkJrhgAAAAAXRePT_E1IEH3FJYm7TS9LAEefyLAgoL5
Visual Think
December 16, 2013 23:09
Add neighbors
Body Other Functions
For the GH120A / GH-120A,
Multi stopwatch / table clock / stopwatch / stopwatch timer, etc.,
Just have an alarm function, a small digital watch with a stopwatch function.
This watch,
I think there are so many users that I can often see at someone's house, and I think it will be difficult to find the manual later.
sometimes,
I do not think it's inconvenient for someone to read this manual.
Below is the manual.
1. Button Description
- MODE : Each time the button is pressed, the sequence changes as follows.
; Current time ? stopwatch ? alarm setting ? time / day / calendar setting ? current time
- RESET : When the stopwatch function is activated
; STOPWATCH STOP - RESET STOPPER TO 00:00
; When the stopwatch is started - On the screen, the first stop is displayed one second, and the second stopwatch is running internally.
(It can be useful when measuring 1st and 2nd records when running 100m)
At this time, press the START / STOP button and press the RESET button again to display the last second
- START / STOP
; When the stopwatch function is activated - Start or stop the stopwatch function
; Time display function - Date display
; When setting alarm or time - Function to adjust set value (time / minute increase, date increase, etc.)
- Back button
; Press once to activate the backlight for 3 seconds (keep lighting while pressing)
- Back round switch
; When the switch is turned off, the alarm sound and the button sound are turned ON (ON character display state is ON)
; When the switch is raised, the alarm sound and the button sound are turned off (OFF character is OFF)
2. Feature Description
- current time / date / day setting
; Press MODE button 3 times in time display mode
? If you press START button,
? Pressing the RESET button (minute blinking), pressing the START button increases the minute
? Pressing the RESET button (time flickering, pressing the START button increases the time,
Change AM / PM after 12 hours
? Press RESET button (date blinking), START button
? Pressing the RESET button (blinking the month), START button
? Pressing the RESET button (blinking day), START button
? Press the MODE button to complete the setting.
- Stopwatch (stopwatch)
; Changed to the stopwatch function with the MODE button pressed once (0:00:00) in the time display mode.
? Press the START / STOP button to turn the stopwatch on and off
(However, if the RESET button is pressed during the stopwatch operation, the stopwatch stops, but internally,
The second clock is still running, press the START / STOP button once,
When the RESET button is pressed, the second stopwatch is stopped)
- Alarm function
; Press the MODE button twice in the time display mode (the flashing hour part appears on the screen)
? Timed by START / STOP button
? Pressing the RESET button (blinks for a minute)
? Split by START / STOP button
? Press the MODE button to enter the time display mode (create a bell shape on the screen)
; Disable / set alarm function
If the RESET button and the START / STOP button are touched simultaneously, the bell disappears and the alarm is canceled.
(Press again the RESET button and START / STOP button again to display the bell shape and activate the alarm function)
- SNOOZE
; When the alarm sounds, pressing the RESET button completely turns off the alarm,
; When you press the START / STOP button (bell blinks)
; After the alarm is turned off for a while, the alarm sounds every 4 to 5 minutes.
; To turn off the alarm completely, press the RESET button.
- Hourly time signal notification
; It is a function that sounds once every hour,
; While in the time display mode, press the MODE button while holding down the RESET button.
; When pressed,
; If all the day of the week display is visible on the screen, the time notification function is ON,
; OFF state if no day of the week is displayed on the screen
- Backlight function
; Press the round button on the back once to activate the gauge for about 3 seconds (press and hold to continue)
- 12/24 time system change
; Press MODE button 3 times (second blinking)
? Press the RESET button twice (at the time)
? Press the START / STOP button once to alternately display AM / PM / 24 hour display with increasing time
? Press the MODE button after setting is completed.
This concludes the GH120A User Manual (manual) posting.
Similar Problem. All lights but the message indicator are solid green. The message indicator is blinking green. I have run a network sniffer on the LAN port and found no traffic. I unplugged the phone by mistake when I was in a setting menu. Since then the phone as been non responsive.
