SOURCE: I have a GE Cordless
Hi anewearth,
With the indulgence of Compurepair, ivofreax10 and ser71....
If I understand your concern right, on your GE Cordless:
1. red light flashing onincoming call,
2. replaced the battery;
3. displays "READY", "TALK" or "UNAVAILABLE";
4. receive audio messages on the answering machine;
5. receive incoming calls.
But
a. no dial tone;
b. no ringing;
b. no dial out.
Things you can try:
i. unplug the base from the mains for over an hour to reset the system;
ii. once powered back, place the handset to the base unit's cradle for half a minute to "pair" the two. Pls try redoing the setup steps again;
iii. check if your home telephone wiring uses the 4 wire. the GE to my understanding is 2 wire only. If you have used the phone previously without this issue, pls disregard.
iv. if the handset battery is new, pls try charging overnight.
v. verify/try that this is the only phone connected to your phoneline;
vi. verify that Ringer in the handset is set to ON.
Resetting the system can and may delete all stored information.
If all else fails you may need to contact GE at 1-800-448-0329.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Alcatel advance reflex 4035, attached
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
SOURCE: ALCATEL 4028/4029 PHONE. WOULD
Depends which Alcatel system the 4028/4029 is connected to.
If OXO, you will require an external music source to be connected to the AUDIO-IN port on the CPU (RJ45 plug using pins 1&2) and is recommended to install MOH/Paging isolating transformer.
To enable background music on 4028/4029, hold the green speaker key for several seconds. Starts flashing and the volume can be adjusted with the + & - beside the mute key.
To disable, just repeat hold process.
If OXE, will require engineer to program softkey & again will require an external music source...
Good luck...
SOURCE: Pick up handset to answer a call and NOT have to press a line
if your phone had set for ringging assignment, u no need to press any key to answer the call.
check the indicator light,
if green light turn on, u can direct answer the call
if red light turn on, u ned to press the line to answer the call
kindly ask the phone provider the set yr extention for incoming ring assignment
