SOURCE: Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
SOURCE: Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
General tips
Good luck !!!
Regards
PCmania
SOURCE: Noisy & shaking spin cycle and smell
The shaking could be your shocks beginning to go bad, an unbalanced load, unbalanced machine, or even possibly weak flooring. As far as the smell you can purchase a product called "AFFRESH" at your local parts distributor which works well to removed the mildew in the gasket. You just put the tablets in and run the machine through a cycle. You could also wipe the gasket out with a wet rag.
Be sure to leave the door cracked open between cycles this will help prevent mildew from building up.
Hope this helps _MJ_
SOURCE: I have Indesit WIXL 123. During the last load, I
http://www.devicemanuals.com/company/Indesit-manuals-page6.html
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.washerhelp.co.uk/washing-machine-repairs.html
Sounds like your clutch, or your motor, or belt, if there is one, has a problem, please use these service manuals to troubleshoot and hopefully isolate and repair your problem.
Testimonial: "Thank you my hun, I shall investigte using the manuals and see if i can pin in down. Thank you for taking the time to reply, and ill let you know how i get alon. Once again, thank you :-)"
SOURCE: noisy bearings on spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
