FYI: for F2 error; it's a "Communication failure between EOC and ESEC system. Recommended action: Test harness/connections P4 (EOC) & P11 (Surface Element Control Board). If harness checks OK, failure can be caused by faulty UIB, surface element control board, or EOC."
Well of course the F2 is the error for runaway temperature, and so based on that, it looks like the sensor or ERC could be bad, however check the connection for the sensor
Hi It seems that the Hard Disk is disconnected from it's connectors It needs to be fixed and installed correctly. To do that, there are screws in the back, remove them and disconnect the hard disk, and reconnect, fix it correctly. If it's difficult to you, go to technician to do that.
Thanks for using FixYa. Error E0-F2 means shorted
keypad and to resolve this issue you’ll have to replace the electronic range
control/keypad assembly. Please do rate the solution
if the issue is resolved or post a comment for further assistance. Thanks Rylee
You have the following error.
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
The F2 error code on your microwave oven is a membrane failure. It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
Chia, this is not a good one, F2 is a keypad failure or interface mismatch. You can try a couple of things. 1. unplug the washer for a minute and see if the code returns. 2. Remove the consol to access the control board, three screws on the backside and the consol lifts up. On the right side you will see the main board. On the right side of the board, center harness will be the interface ribbon cable. Reseat it a couple of times. If this doesn't work, I believe you will have to replace the touchpad. Catriver.
How d I repair the problem
