SOURCE: Stuck on spin
With all do respect to Parky16, I'm not sure you know what a Fisher & Paykel unit is.
It sounds like you have a drain pump problem. You will need to get the water out. With a shop vac or something. Tilt the unit back on a milk crate, paint can or pull it out from the wall far enough so it will not fall down.
Looking up from the bottom on the left front side you should see a small pump. If it has been out of balance or has sucked something up in it the fan blade may be stopped. If not you should be able to freely turn this blade. If you can't turn it you have and internal clog.
If you get this far and don't want to call a repairman out let me know.
jim
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: HI, lights 3&5 from left.are on and
did you ever have any luck with this as my washer is doing the same thing?
