SOURCE: My kindle is frozen on one page. The battery is
Looks like your kindle logic board is defective. You can get the logic board at Kindle Repair and there is a guide that shows you how to put in the part at Electronics Repair Guide.
SOURCE: My kindle is stuck on a page. It won't change
Are you sure the Kindle powers up? It may show something on the sreen, even if it is not turned on (e-ink screen does not need a powersupply to show an image). Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
SOURCE: while reading my kindle screen went dark and the
You most likely need a new screen. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
SOURCE: Kindle stopped working. When I
Apologies, this is not a solution, but just to say that I currently have exactly the same problem. Have you managed to fix yours?
SOURCE: My kindle is frozen. I cannot reach my home page.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
