Go to www.frigidaire.com
>Customer Service
>Product manuals>your model number
>right click to download tech data, (which will give a repairmans info )and any other manuals you think you might need.
These are in PDF format. so if you don;t have adobe acrobat, you need to go to www.adobe.com/acrobat and download the free software so you can read the manuals. Once you have the manuals you can click on the little icon which is a stack of pages on the left column to go through the infomation,. Good Luck.
Machine won't spin and was giving E47 error code. Checked resistance on PTC heater and it was normal (about 1500 ohms). Replaced front door lock assembly and it fixed the problem.
I think resistance test is not good enough to know the switch assy is ok or not.
E47 is a door lock error code ...Check that the wires are all connected change if they areall good you will need to change the door lock..
Krazytech,
I finally got a look at it today. I wish the parts houses would show a picture of it before I order.
Thanks,
A few months ago the 1st error code was E20 and your solutions took care of it with removing bra pads, etc. It was doing the same thing and once again I removed bra pads, etc. Well, it still didnt drain so I checked the error code which is now E47. What do you think it is?
Thanks
