Tv turn on now,have a flashes a picture only a few sec.than dies and have sound left only?Yes,than those 2 long boards to the left and to the right call the LCD inverter boards are dead.These 2 long LCD inverter boards,job are to help the LCD screen panel to have a backlight to produce a pictrue.Tries websites like Shopjimmy.com.Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Hi ,
Power on the unit in the dark room then aim a bright flashlight directly to the screen, you will barely see the images. This is because your backlight is
not functioning. The following reason is the caused.
1. Power supply - missing
B+(supply voltage) coming from this board feeding the inverter board. This is
caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible
resistor.
2. Inverter board - even
the B+ is good from the power supply, if the fuse, driver transistor, driver transformer
is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even
inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would
advice you to look for an experienced
technician to isolate the
problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
