First try changing the display resolution by going to display properties in control panel. Move the slider to the right. Hit apply.
If this doesn't help you out, it could be a display graphics driver problem. Try going to the support website for the laptop manufacturer and download the drivers for the display adapters.
Your resolution settings may not be correct. Try following these steps to solve the problem:
- Go to The Control Panel
- Go to Display
- Go to Adjust Screen Resolution
- Set the resolution to a higher setting until you get the ones you had set before
- Save the changes
Goodluck!!
1. Right-click the desktop, and then click Properties. 2. In the Display Properties dialog box, click the Settings tab. 3. Drag the Screen resolution slider to the left to decrease the resolution of your monitor, making text and pictures appear larger. Or drag the Screen resolution slider to the right to increase your monitor's resolution, making text and pictures appear smaller. 4. Click Apply to have the new resolution take effect. 5. If the Monitor Settings dialog box appears, look at your display. If you like the new resolution, click Yes. If you do not like the resolution, click No, and return to step 3 to try a different resolution. 6. Click OK.
