Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Hi I have a Sony Bravia KLV-40S200A which wont turn on. The standby button flashes five times then pauses for about 4 seconds then flashes again. Any ideas?
  • pa05065 Dec 09, 2010
    Thanks for the tip. I actually turned the tv off at the wall and left it for an hour. It was working perfectly when I switched it on again so I'm very happy - Cheers
  • 608 Answers
I had a similar problem with my 42 Inch Philips 42PLF5432D/37 LCD HD TV. It would turn on but then shut back off after about 10 seconds. Then it wouldn't turn on at all. The problem was a bad capacitor. Several bad capacitors. They are inexpensive and fairly easy to replace if you don't mind digging around in the back of your set and soldering some new ones on your Power Supply Board. Or take the less inexpensive route and look for a whole new Power Supply Board. Good luck. Hope this helps.
Posted on Dec 08, 2010
  • Kaufman605 Dec 09, 2010
    Nice
    No problem
6ya staff
SOURCE:
Klv 32s200a
There are two things you can try. Press "Sleep" until you see "off" appears. If this doesn't fix the problem, go to the "Eco" settings and set "Power Saving" to "Off", set "Idle TV Standby" to off, and "Auto Shut Off" to "off". I hope this works for you.
Sep 20, 2013 | Televison & Video
The red standby light flashes in the code of 4 times then pauses then 4 times then pauses
Five times blinks to Sony Bravia is related with an IRK error. It is related to its main digital board. In most cases, the main board might need replacement. It will be best to contact the authorized service center for Sony. If you're sound in electronics, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
Jul 19, 2013 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Jun 02, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Diagnostic Test Indicators
When an error occurs, the POWER LED will flash a set number of times to indicate the possible cause of the problem. If there is more than one error, the LED will identify the first of the problem areas. If the errors occur simultaneously, the one that corresponds to the fewest flashes is identified first.
LED ERROR DESCRIPTION CODE
1 Supply Voltage Trouble Panel 5V UNReg (10.5V)
2 DE5V Voltage Trouble FE5V (DCALERT2)
3 Voltage Trouble D3.3V/D2.5V/D1.8V. (DCALERT1)
4 Backlight Trouble
5 Main Supply Voltage Trouble (17.5V.DET)
6 Speaker Applied Voltage Trouble
7 Monitor an Increase in Inside-Temperature (esp. on the panel side)
8 Trident IC Trouble
Apr 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
KLV 40S200A
If you watch how many times the light flashes and then relay that to your local authorized sony repair centre they will tell you what is likely wrong with the TV. Have you unplugged, left for a couple of minutes and re-plugged?
Sep 07, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
468 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
