The solution above doesn't deal with the all important issue of what to do once the waste counter has been reset.
It is not sensible, smart or a good idea to reset the waste counter and then ignore the waste ink as if it had just gone on holiday. The waste ink still exists in the waste pads and will invariably reach a point where it will leech out of the pads and start leaking out of the printer.
The 1400 is easily fitted with an external waste ink kit as demonstrated here:
http://www.octoink.co.uk/pages/Epson-1400.html
Also worth noting that some 1400 printers have faulty firmware which does not allow the waste counter to hold the reset. Updating the firmware is required which means taking the printer to a service centre or finding a source of the necessary firmware and tool on the net (there are sources available).
Q: What should I do if my printer driver displays the message parts inside my printer are reaching their end of service life?
A: See the Epson Ink Pad Reset Utility page.
Epson Ink Pads Reset Utility
If your product is displaying an end of life service message, please view and complete the required information below to proceed.
Please explain the message I am getting in my printer driver that says parts inside my printer are reaching their end of service life.
Like so many other products, all Epson consumer ink jet products have a finite life span due to component wear during normal use. At some point, the product will reach a condition where either satisfactory print quality cannot be maintained or components have reached the end of their usable life. This is the normal product life cycle for highly mechanical devices like printers. This message is a warning that certain parts have reached the end of their usable life and that your printer will no longer work until it is serviced.
What parts are we talking about?
The message refers to the ink pads, which are actually a number of porous pads in the printer that collect, distribute, and very importantly contain the ink that is not used on printed pages. Ink is collected by these pads during the initial setup of the product, during cleaning cycles and when printing borderless photographs. Most users will not receive this message before the printer is replaced for other reasons. Some high volume users or those who use the printer for many years may receive this message about ink pads before other components reach the end of their usable life.
Why does my printer stop functioning when I get the message?
Epson is committed to ensuring the proper operation of all our devices to minimize the risks of property damage or personal injury during the lifespan of the product. The printers are designed to stop operating at the point where further use without replacing the ink pads could create risks of property damage from ink spills or safety issues related to excess ink contacting an electrical component
Is there anything I can do to continue using my printer?
Epson recommends replacing the printer, but if you want to continue using it, Epson recommends having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. Please note that replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Epson does not recommend ink pad replacement by users without technical training or resetting the Ink Pad Counter without replacing the ink pads.
Note: This utility is for Windows XP and Vista operating systems only. We hope to develop an option for Mac users as well; however, we do not have an ETA or the OS requirement at this time.
To download this utility, please complete all fields below, select the agreement check-box and click Download. Required fields are noted with an asterisk(*). Some models may require you to be redirected to another website to finalize the process.
Go to this link to complete the agreement to recieve the Epson Ink Pad Reset Utility.
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Trust this is helpful. :)
SOURCE: Parts inside your printer are near the end of their service life.
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
SOURCE: Epson printer -parts at their end of life!
Review online guide and trouble shooting for suggestions.
The manuals,online guide and trouble shooting sections could help you resolve your problem. Contact support has a chat facility on some pages that may help.
Click this Link
Under Select a Product Range
Choose Laser Printers on the webpage
Choose Aculaser C1100 on the webpage
Under Select an OS
Choose the operating system on the machine where you will install the printer on the webpage
Click Confirm Selection
The manuals and documentation link will allow you to download manuals that were on your CD ROM
you may want to bookmark the online guide, if present, to help with future problems -- that probably was not on the CD
Click the back button on the browser
click the Drivers and Software Link
This allows you to download software files that were probably on your installation CD
Click the back button on the browser again
Trouble Shooting and Contact Support could be an interesting link in the future too when and if you have problems.
I hope this helps
Where can I find ink pads for my Epson Stylus Photo Rx600 ?
August
[email protected]
SOURCE: Parts inside your printer are at the end of their service life. See your printer documentation
when i swich on my Printer C43, both the indicator lamp is blinking, and tehn appear the message:
"Parts inside your printer are at the end of their service life"
