Washing Machines Logo
Posted on Dec 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It will not spin, it does everything else ok - Maytag Washing Machines
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Dec 09, 2010
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
611850
Points
4917
This problem is commonly caused by the failure of the door lock system. The machine has a safety feature that prevents the high-speed spin cycle to commence unless the machine control detects the door is locked through the door lock switch.
Check if the door lock light is lit. If not, then the door lock and/or the machine control has indeed failed depending on the model number of the machine. If yes, then the motor speed control is the problem. Indicate the exact model of the machine for more specific troubleshooting and repair advice. The model number is necessary for exact replacement part numbers should a part replacement is required.
2answers
Will not spin, drains OK. belts ok, pulley under drum spins ok when turned on.
Hello & Welcome to FixYa
The problem is with the lid switch that is bad and needs replacement as you have already checked everything else. Please check this diagram....part#11 is the lid switch...if you want you can also try to jump it. Please get back to me if you have any other questions.
Kevin
Whirlpool washer wont spin during spin cycle everything else appears ok.
Machine not spinning....check]
1..all water gone clean pump trap and check blocked drain
2....somehting stopping drum spin drum freely by hand.
3....too much soap use low suds soap and very little of it.
4....motor brushes wearing out...call for service for this one.
Good luck
T
Machine won't spin... Machine gets water,
only be one thing, the wig-wags are not shifting transmission into spin if everything else seems ok in operation
Saying no rdy on cd player (Emerson)
make sure you have a cd and your tray spins when opened
1 year old kenmore washing machine won't spin, agitator works OK and the water drains, just won't spin.
you have a bad door switch everything on a washer works fine with a bad door switch except the spin cycle
Not spinning at all
your washer needs a new speed control board located in the bottom right corner of the machine it controls everything to do with the motor
2helpful
4answers
GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
