Step 1
open drive where data is save
after it open your company data folder
than you have find a file (TMESSAGE.TSF)
it's error code 0
select this file and deleted its
after above process 100% your problem solve out
thanks mr.param _para ., this was really helpful
Param_para M9, thank you so much for your solution. It really worked. :)
thank you very very much
thanx a lot...really helpful..it worked..
thanks mr param it was realy helpfull ... i can solve my tally problem by following your instructions ....
Thanks.........
THANK YOU VERY MUCH
Thanks
Thanks it really helped
Dear not solve
Dear sir,
our telly erp9 getting error as:
Internal error. contact tally solution
unable to read massage 0 for update!
Error code :0
please get the solution
thanks
for central motors khandwa
9425929011
Our telly erp9 getting error as:
Error code :0
Ohhhh thank you for your suggestion for my problem is solved
SOURCE: HEN I WAS OPENING TALLY ERP 9 I HAVE BEEN FACING
Step 1
Windows Key+R
in the Run Box
Type your Tally Folder Path as following
Eg. D:\Tally.erp9\tally.exe data 0
when open Tally Getway
use Ctr+Alt+R
Rewrite All Company
Enjoy....
IF Problem is same
then in the data folder company number folder
delete all tsf file and attem step 1 again
Problem is 100% solved.
AYS, Beawar,
Thanks to Mir -- Manish JI Garg..
