SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
SOURCE: tv shuts off spontaneously. red power light blinks.
re: sony flat panel lcd tv mod. # klv s 40a10.
No power. When power button is pressed, nothing happens.
The stand-by at the power supply ( cn6201) measures to be 3.47 v. instead of 5 v. However, when I unplug cn6201 (5 pin connector) I can read 5v. at the power supply.
Any suggestions?
