Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
My computer was working fine, all in order, but then all of a sudden my keyboard does not work, from start up through bios till the password logon screen, i can't access windows and change any settngs as the keyboard does not respond, the initial keyboard i was using was a ps2, i have tried another keyobard that i am sure it is functional and another USB keyboard to no avail. anybody to help me out on this problem.
  • Foxconn Master
  • 1,830 Answers
How old is your computer?
Posted on Jul 20, 2017
6ya staff
SOURCE:
Anonymous
  • 9 Answers
SOURCE: After 18 month the computer will not go into POST on a re-start but will start normally when completed turned off.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
Posted on Feb 24, 2007
Anonymous
  • 84 Answers
SOURCE: PS/2 Keyboard not Working
ps/2 means the north bridge chipset is going ( just not totaly dead though ) in time you may notice the usb may not work at 2.0 speeds
Sorry nobody on this planet can repair a ps/2 unless another motherboard is purchased .
Posted on Aug 08, 2008
SOURCE: Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Posted on Dec 07, 2008
Anonymous
  • 13 Answers
SOURCE: PS/2 to USB adapter Issue
go to Control panel, click on your mouse icon and set the settings for your mouse
Posted on Jan 23, 2009
Andrew Ermel
  • 326 Answers
SOURCE: Just put a computer together
I would assume you've tried different ports and different keyboards.
If you have, I'd contact the reseller and RMA the board.
There's really nothing you can do with a board that won't go into the setup.
Just for kicks, remove the CMOS battery on the board before you email/call the reseller.
Posted on Mar 16, 2011
How do you reset a Dell Inspiron E1405 bios password?
Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
hope this helps
Feb 02, 2011 | Dell Inspiron E1405 Notebook
I cannot open my friendster account because i forgot my password.pls.help
Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
hope this helps
Jan 28, 2011 | Computers & Internet
Acer laptop keyboard does not work at all, can only get to logon screen and then can't logon to computer because the keyboard doest not work. Mouse is fine, plugged in external keyboard via usb and that...
When you start your camera, press F8 and then choose Command line model and see if the keyboard works, if works, you can install the operating system to solve the problem simplest . If not, there maybe hardware error
Jan 10, 2011 | Computers & Internet
What is the default password bios of the HP
There is not default password as such but it comes up only when it is created.In order to get rid of the password we need to boot the computer to the BIOS .
Turn the notebook off and then when you turn it on or lets say as soon as you press the power button to turn it on start tapping the f10 key on the keyboard repeatedly till you get a screen that says BIOS SETUP UTILITY ,once you are on that screen press the f5 key on the keyboard it displays a mesage that says load default,press y for yes on the keyboard and then press f10 that displays a message which reads save and exit again pres y for yes and the computer restarts .Once it boots up should not for the bios password.
hope this helps you ...all the best
May 21, 2010 | HP Pavilion N5150 Notebook
Computer has been working fine. Now all of a
When system boots press the key to get into BIOS. Usually it is 'Del' Key. Once you get into BIOS, if not asking a password, get into admin menu and set the password option disabled.
If asking for a password while you get in to BIOS and you dont know the password, the only option is to reset the BIOS.
To reset BIOS u've to remove the back cover and remove and re-insert the CMOS battery while the laptop is powered off. After that, power on the laptop and set the bios to normal setting, especially the time. This wont harm any of your data.
Please come back and vote for me if this finds helpful for you. Thnx
Mar 28, 2010 | Computers & Internet
Numeric Keypad doesn't work after windows XP logon
pause your antivirus and plug ur keyboard pin
Jun 18, 2009 | Computers & Internet
Acer Aspire One Notebook - asking for password on logon
try clearing the cmos setup
your can do this by removing the cmos battery or you can try press "f" and "j" while starting the computer
Dec 26, 2008 | Computers & Internet
Help me
Witch password???
Bios password???
Everex has a known problem with this model of laptop. It has been known to set its bios password by itself. It is a simple fix, but should be done by a proffesional. There is no charge for this repair at a Everex repair center.
If you want, this is what needs to be done. Remove the piece of plastic above the keyboard. Unscrew the 2 screws in the keyboard and lift the keyboard up( No reason to disconnect it ) Unscrew and remove the modem card in the center. There is 2 solder points c88 on the system board. You need to short those 2 points out while you press the power button on. This will reset the bios password. This should take someone about 5 minutes to do.
If this solved your problem please rate this solution as "Solved" or ask here again in order to find another possible cause
Oct 25, 2007 | Everex StepNote NC1500 Notebook
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
43 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
