Two possible issues
one unplug treadmill remove hood and make sure the main power cable to the motor controller box is in tight power back up and see if that worked
two you might have blown your overload resistor on the motor control board (mcb) . unplug treadmill and remove the motor control box . remove the motor control board out from inside the box and inspect it for damage and/on electrical burn smell. if you find damage you have to get it repaired. contact glide fitness products in santa ana california 1 866 637 4600 to get all information including shipping. it cost $200 plus shipping which is a deal considering a new one is $1000 . if you do send it in for repair remove the wax board and electrical componeton the outside of the box and put in a safe place as you will need to reinstall them on the new box the most common cause for the overload to blow is friction between the belt and the deck board ,if you have an auto waxer the nozzle is usually plugged clean the nozzle once a month . contact glide regarding non clogging wax if this is best for you
good luck
