Sentry Fireproof Safe Logo
Posted on Dec 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ILOST THE KEYS;I HAVE THE COMBINATION - Sentry Fireproof Safe
tmburke
Level 2:
Novelist:
  • Expert 76 Answers
  • Posted on Dec 12, 2010
tmburke
Expert
Level 2:
Novelist:
Answers
76
Questions
0
Helped
144841
Points
132
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Unlock car without keys
I have 4 dial brass combination lock, and I can not open the lock, how I can set a new combination , the existing combination is not working
V332 combination insruction
Try this:
http://www.1stvision.com/cameras/IDS/dataman/uEye_User_Manual.pdf
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
1helpful
Ilost some of the channels on my panasonic tv vhs combo how can reset it my model # PV-M1323 THANK YOU
What you have is a bad tuner in the set---2-6 is low vhf band-7-13 is the next band--14 and above is the next band of channels---clearly your 7-13 band is bad.
The tuner may be able to be removed and the board inside it resoldered---a replacement tuner even if available would cost more than a new unit.
My computers screen changed to show the picture sideways. what do i do to fix it
You must have pressed a combination of keys that cause the problem. Press a combination of keys- "Alt + Ctrl + arrows keys "
Alt + Ctrl + up arrow key will again straight the image of the monitor.
1helpful
2answers
Sentry safe v260 . have both keys but forgot the combination. how can i over write it?
If you have a "3 number combination" or have a "4 number combination you that you have NOT changed", you can send in your serial number in a notarized letter and $8 to: Sentry Group, Dept 200, 882 Linden Ave., Rochester, NY 14625-2784. (this info is in your Owners Manual under Lost Keys or Combination) If you don't have your Owners Manual you can download it from: http://www.sentrysafe.com/products/productDetail.aspx?s=130
If you have a "4 number combination" and you HAVE changed it from the original cobmination, the only solution you have is a locksmith.
2answers
Replaced the ignition lock and tumbler. Alarm going off nostart
you need to have the keys programmed with a ford scantool. that's the only way.
Lost keys alarm is now going off.
need to be reprogrammed at dealer
Presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
1helpful
2answers
Geo metro 94 lock cylinder removal
I have a 97 Geo metro with a broken key inside the ignition. I have removed the column cover and have access to it but don't know how to remove the switch
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
